Exchanging the japanese radio/navi for an english language one - what to use
Guys, basically I got one question.
So I still have the double din radio/navi in my car and besides that I only got unusable japanese frequencies in the radio, it only reads CDs and is 99% in japanese - it is working fine ^^
It also has a rear port ( cinch ) for the rear camera, which automatically starts and gets projected on the screen as soon as I hit the reverse gear - do many radios have such a port for a camera and will the be activated too directly or is it a question if additional signal cables from the gear to the radio to let it know, when to project the rear view?
Sorry if this isnt good english but as I said before, Im german. :D
Thank you guys ❤️
BTW: The radio is a clarion addzest something road explorer 3.0 HDD
Just about any double DIN car stereo with a big LCD screen would have a video input for reversing cameras.
I don't know about how the signal and screen are activated in your car. AFAIK R33s didn't come with this stuff. Are you talking about some later V series or Stagea? Actually, I don't even know how the camera and screen are activated in those later cars either. But it is quite possible that there is a "reverse" wire that comes from the gear shifter reverse switch or from the BCM that would tell the stereo to switch over to reverse camera mode. Or, it could be that the stereo automatically does so whenever the camera signal goes live.
Ah I see, but you couldnt say that they all got this input point in form of a cinch plug I suppose?
Yeye, its my R33 Gtst. Looks like I would have have to take the radio out and have a look where all wires are going or if one directs to the gearbox or something. Sigh ^^
It has to be one of two no?
Get the camera power as soon as you hit reverse and the screen recognizes that and switches OR
tell the screen when it is reverse and let it switch to the always powered cam
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
