Hey guys,
Although i am in the UK, hoping you guysc an help me out with identifying some OEM shock absorbers i can get for my R34 GTT.
I tried looking at the KYB & Monroe website for OEM parts (i got a standard R34 GTT) , but nothing shows up  :(
I cant imagine the the GTT has specific shock absorbers that no other car uses  (I wonder, given the rear brake rotors on the GTT are the same as the Z32  300zx/Fairlady , wonder if the shocks are ?? )
Trying to either find the Nissan OEM number, or the KYB part number for the shocks, or any standard OEM spec shocks i can use ?
Any ideas ?
https://www.sau.com.au/forums/topic/481834-r34-gtt-oem-shock-absorbers/
Do you want to be cheap? Or do you want to buy decent dampers? Because Bilstein B6 is the minimum that I would recommend for direct fit dampers.
Nothwithstanding that, I just typed "r34 kyb rear" into google and the first 2 hits were for an eBay listing and the actual web shop of this crowd here in Oz offering this https://www.superspares.com.au/2-rear-kyb-new-sr-special-shock-absorbers-for-niss~12193763
cheers for reply, not looking for cheap, just oem (standard car).....
I found the original part numbers last night, and the SR range of KYB for the R34 GTT  (same as your link)..
The idea was to buy OEM shocks, and add my Tein S springs to the shocks (already bought the springs before my pal told me i got x2 leaky shocks) .....
Being in the UK, coilovers are easier to obtain that shocks!
Selected Vehicle:
NISSAN SKYLINE R34 ER34 05/1998~05/2001 2 Door Coupe 2.5 litre, RB25DET I6 24v DOHC Turbo MPFI {208KW} RWD,AT/MT,[JAPAN] 12272
Shock/Strut - Front
image.gif.6280203887490948211e6610e1fa5d02.gifA12C6E050DA21BF458277473440D1DAE3F0A1B0612CB7F983FAB3430EFF3C0AB.jpg NSF9092
New SR Special - Enhanced Performance
2 req
Shock/Strut - Rear
image.gif.7913e75b64ab70f76943c3d75e0ccdae.gifB17930682718FF60403DBE2831C80BA316E2DA175F775161D39B804AA5C6ACA9.jpg NSF9093
Suits Lower Eyering Mount Type
2 req
image.gif.9e6349fdf5e9c0b867aa5df3a3bdfc38.gifB9231E6738C028BA6761DCDFCCD05568A349DBB80C78E24729E4E8E81FFBC2D3.jpg NSF9095
Suits Lower U-bracket Mount Type
2 req
Those Bilsteins above are for the GT with eyelet bottom. The GTT has fork bottom, like the GTR. But you can get B6s and B8s for GTRs, so I can't see that there would be too much trouble getting one for the GTT. I mean, superficially, you could just put the GTR one in. It will fit.
cheers guys
Turns out, i need to send my springs back to the supplier, and get coilovers instead...
And yes,I was looking at OEM (nissan), or a manufacturer that made OEM spec shocks for the car..
As said, mine is standard, but at the same time, was trying to keep my costs less when buying shock absorbers, compared with buying Coilovers....
The B6 & KYB SR shocks, even the Nissan OEM shocks = cost more than Tein Street Advance Coilovers.....
So end result is, i need to switch anyway....
Cheers for the replies though guys :)
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
