I’m having an issue with my R34. I left my headlights on and the car battery died. I went out to jump start the car and left my headlights on. It obviously didn’t start, so I turned my headlights off and started the car again. But now my headlights don’t seem to turn on at all, and only 1 of my high beams work. I checked all the fuses in the engine bay and they all are good. I thought maybe the bulbs somehow got blown but I checked for continuity and they seem okay. I next checked the wires connecting to the bulb for continuity and they seem fine too. I’m wondering if maybe I somehow fried the turning signal stalk by starting the car while the lights were still on.
Any ideas of what might be happening?
thanks in advance!
https://www.sau.com.au/forums/topic/481841-low-beams-not-turning-on-r34/
Get the wiring diagram out. Remove the headlight switch loom plug and probe for where the power is supposed to be. That will tell you if you've missed something upstream (like the real fuse that you should have checked). Probe for continuity across switch terminals that are supposed to be continuous when turned on. Plug it back and in and probe to see if power turns up on the output side of the switch.
Etc etc etc.
Somewhere there will be a wire that is broken or burnt, or a fuse that is is open, or a switch that has melted or burnt in the wrong position. The wiring diagram shows you what you need to be looking for, and where.
I'm still a little confused about this.... I removed my turn signal switch from my car and I'm trying to test if it's good or not. If I understand the diagram correctly, in the Lighting SW area of the diagram, I set my switch to 1ST position and check the pins for continuity. So I put my multimeter on Pin 1 and Pin 9 and set my multimeter to resistance. I test the pins but it it seems like there is no continuity there.
Am I reading this diagram wrong? What do the Hi/Lo/P stuff mean?
Not sure if it makes a difference but I don't have an AUTO mode on my switch. My switch also doesn't have all the same pins that are shown in the diagram. I've attached an image of the wiring diagram for convenience.
Wiring Diagram
I'm sorta a noob at electrical so anything helps.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
