Hello,
I have a full stock r34 gtr however the brakes locked.
Brakes are fine (pedal feels good), I had to go over 90km h under rain to make it locked.
no brake leakage and brake fluid level is ok.
I'm using used (good conditions) winter tyres.
abs goes on and off after ignition is switch on.
I had a fault code 72 that I clear and it didnt get back.This fault code was relating to TPS (MFD show correctly the TP) I also checked the TPS signal on the abs connector and voltage is within spec (0.5 - 4v)
I checked the wheel sensors from the connector of the abs module I got values (using a cheap chinese ohmeter) between -0.5k and +8k (depends at which speed I turn the wheel ) with average/rest at 1.2k
during the wheel sensors signal measurements; I moved/shake the wheel sensors wires/connectors to make sure there is no short or open in the loom/connector/sensor.
I'm out of idea ? can it be a relay ? fuses ?
best regards
https://www.sau.com.au/forums/topic/481886-r34-gtr-abs-not-working/
Thanks for your answer however now I'm out of idea...
I have performed the following tests :
- continuity test between the wiring of the abs pump and the abs ECU
- ring abs sensor are in good condition and have the correct number of teeth (46)
- all fuses are ok
- tyres are globally in same condition; is within +/- 10mm
- I have electrically disconnected the abs pump to test it :
* relay are ok (80 ohms and I can "hear" them when I powered them)
* solenoid valves seems ok (4 ohms or 8 ohms and consummes 1.5A or 3A; it will depends if it's an inlet or outlet)
* the abs motor is working
My questions :
- I have a front limited diff slip, is it possible that's making some trouble with the ABS ?
- should I open the abs pump to check the valves ?
- should I go for new tyres ?
- where can I found the software to use with nissan consult to connect to the abs ECU (so that I could log some infos)
Any other idea maybe ?
Thanks for your time
so I have bleed the entire system and the wheels are still locking
I have dixcel m or z type brake pads (I dont know if that could be an issue somehow )
I have order a consult 1 we will see
if I am still getting into trouble I will change the master brake cylinder, abs pump and abs control unit ...
best regards
I finally got a (german) consult
I was able to do the active test with success (meaning the abs pump should be ok)
the wheel data seems to be ok too, they are between +/-1kmh between each other and they are matching the real speed.
I was not able to do the self diagnostic with the consult; I might do something wrong in the process I guess (see picture)
Edited by bigboss59400
I'm suspecting some solenoids being blocked as my wheels are still locking (my feeling is it seems to be the front only ) so I will dissasemble the pump
I have made a test this morning (7am at 1 degre; the road was dry but we some humidity on it; sorry I don't get the english word for it )
you can clearly see from the picture that my abs control seems to react correctly !
if the solenoids valve are in good cobdition, I will put everything back to stock :
  • no winter tyres
  • OEM pads
  • new flexible hoses (avionic )
  • new brake master
thanks
So to conclude,
My assumption was false, based on the curves I provided we can see that the wheels has locked but the ABS release some pressure to unlock them...
Replacing the winter tyres by some regular tyres give a much better feeling too (but I don't think it was necessary)
So at the end, a bleed of the system + some cleaning on the calipers (with a lot of WD40) seems to have done the trick....yes it was such simple
French test has been passed with success this time
I can finally drive legally in a few weeks hopefully
THanks for having a look into my problem.
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
