So the other day i herd (what i thought was) a drastic outrageous statement.....
"That ALL rb30 heads are cracked, EVEN if you cant see it (because the crack isn't all the way through yet)"
and this is regarding the r31s as well as the VLs before you ask.
old mate says its due to the fact that rb30s have hot exhaust gasses on one side of the water jacket and cold water on the other side and these hot and cold conditions are the reason for cracked heads on unmolested engines with 10,000km.
i dont know if this is standard knowledge or not, but id kinda like to molest my engine so the idea of a potential crack in the head doesn't arouse me at all. So what do yall suggest i to do to find out if my engine has an "invisible" cracked or not? and how would i repair it if it was? (if what he says is true)
my engines actually running like a dream at the moment but it did have over heating troubles in the past that were fixed pretty quick
I suspect the cracked head story is from a VL, because their factory cooling system was not set up correctly, so someone drove their VL with a blown headgasket for thousands of kilometers before the engine gave up.
  • Like 1
not setup correctly? what do you mean?
the Radiator is lower than the head, you have to bleed the coolant . Because people werent aware of that and didnt do it doesnt mean there is a fault of the car.
Running off old memory but it was related to the radiator being lower than head and car not being bled properly because of that. R31's rad was higher? Like I said, it's been a long time since I've read about this.
Yeah this is what it was
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
