Yep 09/10 i think they added more memory.
What year is your car?
One of the reasons I am using Uprev. Plus I can self tune. My vehicle is 08.
mines 09, didnt know the memory thing was a thing 😅
19 hours ago, The Max said:
Certainly is a thing but if you're an '09 model, you're OK. Mine is an '09 model too (built 12/2008) and ECUtek'ed.
just wondering what kind of maps do you have?
hey guys I have an 08  370gt that I need to get tuned any
 suggestions on where to go for a tune and which software is better uprev or possibly ecutek (if my ecu has the memory)
  • 4 months later...
so i went and asked - they took at it and said mine didnt have enough memory :(
is that just an ECUTEK thing?
We have ADM G37 and 370gts on uprev with 5 Maps on them. Bit strange.. O.o
dunno but maybe it is an ecutek thing 😥
Is the Ecutek memory thing only an issue if you want multiple maps? If so maybe a single performance map could be supported & be a better option than swapping in a newer ecu 🤷‍♂️
Sure it’s cool to have multiple maps if you can, but not everyone actually needs them. Have a look at your individual situation & how much you would use a valet map etc.
Correct, it's about multiple maps. A single map is definitely feasible but seemingly not all of us have ECUs with sufficient memory for multiple maps.
Frankly, I find the multiple maps thing in these cars to be a bit of a wank but that's just my personal preference.
Edited by The Max
  • Like 1
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
