I’ve created this account to get some expert opinion on what has been the biggest mess up of me wrenching cars. I am floored at this point and realized I’ve made a very stupid mistake.
My car is an R33 GTR. I’ve recently purchased an oil filter block to relocate my oil filter. In my quest to figure out where in the engine bay I will be fabricating a bracket to mount the remote oil filter plate, I’ve decided to cap off both -10AN outlet/inlet while I first start on the car to verify it runs good, thinking oil pressure will still flow through out the motor without an oil filter. I’ve called up the manufacturer of the oil block after the fact to verify this (which I should have done since the beginning) and quickly gave me the news that I f$&ked up very badly. I thought the oil pressure light was probably a result of a faulty oil sensor. Man am I stupid.. Regardless to say he advised my to rehook the oil filter, run the engine with oil pressure, redrain and look for particles in the oil.
Ive ran the motor for a total of 10 minutes or so. How f**ked am I for running the motor with oil but no oil pressure? Should I assume the worst at this point, that being requiring a rebuild?
oh man, thats bad. That is engine out and rebuild it bad, not really fix up mistake and  and see what happens, although you may as well in case you are the luckiest guy alive.
10 minutes! was it noisy?
Not really noisy. Sounded normal
17 minutes ago, joshuaho96 said:
I'm amazed you haven't spun a bearing yet. Engines do not last long without oil pressure.
That’s what I’m afraid of. That I’ve already started shredding the bearing in some way for running it that long. I am anticipating there is some chance that something has not been compromised.
Either way, tomorrow I have some extra fittings arrive to complete the oil filter relocation so tomorrow I will be rerunning it with oil pressure and looking at the oil. My anxiety is killing me and wanting to know of more of a certainty at this point in time
Edited by Ichikohh
If it is running and sounding normal, all you can do is drive it. Unless and until it starts knocking, you will recognise the quite different noise if it happens
Is it better to just run until it spins a bearing? I got the impression that rebuilds are more straightforward if you do it before catastrophic failure.
I'm just some random on the internet. Yes, if the bearings are damaged it will be cheaper to rebuild it before they spin; the longer a damaged motor runs the more likely other parts will be damaged.
On the other hand, my bet is that if it ran for 10 minutes and isn't knocking already, it will be fine and the rebuild is not necessary.
  • Like 2
This guy would need to go and buy a lotto ticket if the crank doesn't need a at least a 10 thou regrind with no oil pressure for 10 minutes !
i just did a rebuild on a totally turn key engine(rb26) never cracked, and mate its not cheap either way. the theory here is if you rebuild it now you may save it from totally destroying your cast block/head completely "maybe". BUT BUT BUT mate ive seen some crazy things(actual things) not only with rb's but with diesel motors where motors have even run out of oil and went for another what ever km because im still using them. sometimes a guy get a break and you can learn from your mistake without to much penny bank flipping. i would without a doubt put it back to normal and try it out who cares its jsut metal mate. when i say try it i mean dont go track it. maybe start it and take it around the block and listen a bit as best you can. may seem like a pain but ive thrown on stock exhaust just so i can hear my motor when diagnosing a serious issue, although gtr's are pretty quiet should be ok. im cheap man and also just an opinion. but ive been around motors long enough to know if it aint broke dont fix it. quit tinkering with shit you dont know mate! get a manual for your car too good buddy. small example, i have an sti that has been blowing oil for 4 years now and i have debated rebuilding it probably 15 times. -50 celcius, still street race it, still pulls hard, still drive it everyday, fill the oil up like its  a type r integra b18c5 and keep going. cheers
  • Like 1
Do what he said.
Drop the oil.  Look for go fast glitter. If you have a sump full of bits of metal/big end bearing you are up for a rebuild.  You don't need to wait for the oil bypass to do this. You can do it now.
If you have shiny metal bits in the oil and you have oil pressure back when you restart it then you have won.
Thought there was some sort of a pressure relief/bypass valve for cold start etc when too much pressure at filter? In which case if you were just idling, maybe still getting enough flow?
On the other hand i could be thinking of a different engine..
His issue is the oil pump picks the oil up feeds it straight into the oil filter and then into the oil passages.
Because of capping it off all the oil would have gone straight back out the oil pressure relief valve in the pump
dump the oil, when its sparky pull the engine
4 hours ago, cachorro said:
Well.. The oil does not looks sparky or glittery. I started the car as well and everything sounded smooth. Not sure if I dodged a bullet quite yet.. Am also mailing out the oil to be analyzed
If there isn't a ton of metal in the oil/filter you've won the lottery.
  • Like 1
Ever see that MCM video when they drove the corolla with no oil to see how long it would last......couldn't believe how long it went and that was giving it the beans too! I'm happy for you anyway man, sounds like you might have gotten lucky
Yep !
Many years ago, i think it was Slick50 or Nulon, ran a promotion where they treated a motor with their silicon additives, drained he motor dry, sealed it up and proceeded to drive it around Australia.
So your right you may well be OK.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
