The motor is brand new never starter.
The crate motor RB28SB was imported for me by Hi Octane Assembled by Tomei.
The head was done by RAMS with full Tomei components, Type C valves, Cam cap studs, Bronze valve guides etc etc. L19 studs, ARP2000 bolts, The valves are Supertech 1mm oversize. I have flow rate charts for the Head. The cams are tomei 290 with 11.5 lift. Tomei Cam gears
Dry sump is  from Ross balancers including sump modification, brackets, pulleys etc
The front diff is a Nismo 1.5 lsd, it has new nismo motor mounts. Ross Balancer, Crank angle sensor kit etc.
Hypertune Plenum, Injectors
I am sure there is other things i have missed. Message me for any questions
Regards
Jack
https://www.sau.com.au/forums/topic/481926-tomei-28-stroker-28k/
