Hi All
I've done a lot of reading on here about what people are doing for turbo replacements and 99% of the time people have or are looking at upgrades - exhaust etc. and the discussion seems to revolve around that.
I'm a little old-fashioned and my car is stock and prefer to keep it that way so am looking for a turbo to suit. I want a bolt up solution and I noticed a lot of you lads talk about the CGC high-flow. I just rang them and they said that if I were to do that, the car would require a tune and would not run right without. Is this accurate? Am I to understand that the stock ECU cannot be tuned so this is not a solution as I don't really want to stuff around too much.
Has anybody here done this i.e bolted a CGC high-flow to an otherwise stock car? What were the results? Did it run OK as is?
Any advice or help would be much appreciated.
Thanks all
If your car is stock and you want to keep it stock, would you not just get another stock turbo if your current one has failed?
If what your saying is you want an upgraded bolt on turbo that is so small it won't need any supporting mods or a tune, you might find G2 highflow is what you're after. See link below -
https://hypergearturbos.com/product/nissan-rb25det-turbocharger-standard-high-flow-service/
Hi Murray, this looks like the same thing CGC is offering. The issue is because the guts are larger there may be a need for a tune (this is what CGC advised me anyway) which goes to my original question.
From the Hypergear website. G2 is happy with the stock ECU and stock fuel system.
G2 high flow is capable of making up to 230rwkws. It is happy to hold factory boost, recommended for Rb20det engines and Rb25dets working with factory ecu and fuel system.
It's GCG. Not CGC.
You could no doubt get Tao (Hypergear) to rebuild you a stock Hitachi turbo with wheels that are not much different in capacity to the original. He would have to have access to plenty of turbines and compressors that are approximately the same as the stockers. It's just that no-one would want to pay the rebuild cost for a turbo that could have been an actual highflow instead. It will cost the same.
A small highflow will work against the stock ECU. But an important point to remember is that any highflow will flow more gas (and therefore air) at the same boost as stock, so will definitely push your operating point in the ECU's fuel and ignition tables further to the right. In RB25 ECUS, this will lead to more richness and less timing, which is not great. Will use more fuel and make less power than it otherwise could.
An actual proper highflow, a better ECU, some injectors and an AFM are sensible modifications.
You won't be able to run a larger turbo on a stagea with a standard ECU. They are very sensitive to changes in airflow, even a mild boost increase on the standard turbo will throw it off.
If you want to be able to return it to stock, best to plug in an ECU like a PowerFC and put the larger turbo on, reasonably easier to return to stock if you want to.
@RBW49N I want it to be as close to stock so I don't need to change anything else.
@GTSBoy&@DuncanAppreciate the sage technical advice
Thanks everyone for you input. So basically if I want to continue on the keeping the car as stock as possible road, I'm gonna need a either a new or decent second-hand stock turbo.
I guess the next question is what's the best source of either of these?
Ta
There are no new ones. These are ceramic turbine, so all the ones that were going to die from natural causes died years ago and were replaced with the spare stock Nissan had, using it all up. Many have been destroyed since by stupidity (turning the boost up too far).
Essentially, any 2nd hand one you can get that was in good working condition will likely be fine used at stock boost for the rest of time. They've had 20+ years to kill off the weak ones.
Yo get one you'll just need to look at the forums for sales, FB groups (shudder), eBay, Gumtree, etc, for people selling them and try to pick one that is healthy. Import wreckers will also have them and might offer some warranty, which may or may not be useful if you don't install it immediately and discover if it is good or is hiding a problem that wasn't visible on inspection.
Ta
There is a always a few for sale on FB marketplace and they do pop up here from time to time. I have one that needs a rebuild if you want it you can have it just come and get it. Then there would be very little down time
  • Thanks 1
Is there even an ECU that can play nicely with the 4AT in these Stageas? I don't mean like a Motec where in theory you could write all of the code to handle that stuff, actual support where there's a base map that is pretty much spot-on for the transmission, just need to change some calibration values to get things like shift mapping to suit, maybe some timing retard adjustments to get the shifts smoothed out as well.
Yes It can be done with the Haltech elite 2500. Full series 2 auto, fuel and ignition control.
Edited by RBW49N
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
