Hi, I'm selling a few parts that are realy realy realy rare to find.
These are intendet for the Nismo nuts out there.
I'm willing to ship worldwide at buyers expense. I can wrap it up realy careful but I'm not responsible for damage or loss of the parcel.
I will consider SENSIBLE offers.
Items located in Germany.
First of all. These beautiful Nismo Cast Turbo Outlet Pipes.
I personally have never seen a set of these before for sale, propably the only set for sale at the momet.
They come on Nismo S-Tune and R-Tune engines nowadays and are not sold seperatly as far as I know.
Very good condition. No cracks. Rear one has a fitting for exhaust Temp sensor as needed for some R34.
They are internally devided even though they are cast. Piece of art.
1700 Euro
Second item are the uber rare OEM Nissan Optional Rear Side Spats.
This are the Rubber ones that go behind the rear wheels, they are realy hard to get nowadays.
Condition is not as good unfortunately, but don't get scared by the pictures. As they are made from rubber and the guy before my painted them without primer or something, the paint peels of. Could be scratched of with a few hours of work.
Also the right one has a small piece cut off at the upper side. Don't know how someone could do that...
Because of the "bad" condition.
950 Euro
Please no discussions about the pricing. Nismo tax included.
I still don't understand the point of dividing the wastegate from the exhaust turbine. Does it actually matter? I get the distinct impression from modern designs that the answer is no.
It makes good sense from a fundamental flow point of view. The very best turbine outlet is a pure cone, growing at 7-10° from the turbine outlet diameter to the main dump pipe diameter. Nice and straight, no bends. That's the ideal - straight from the mouth of a Garrett R&D engineer. These details are all about obtaining the best pressure recovery (across the turbine - not trying to maximise pressure in the exhaust, which is what we normally mean when we talk about pressure recovery after a disturbance).
The shallow cone angle is intended to prevent any unpleasant separation effects (that you get with wider cone angles), but this is one area where I suspect that the difference might be tiny. The turbine exit flow will be coming out with a large amount of swirl and will want to expand (purely from centrifugal force) and will push up hard against the wall. A wider cone angle would probably be indistinguishable from a shallower cone angle. But....
That horrible swirling flow is fine and dandy when it is trapped in a nice conical expansion. But when you drop it out into a suddenly opened up space (like the common turbine and wastegate outlet cavity in many integrated turbine housings) then you get a mess. The turbine flow does not have the opportunity to depart the turbine cleanly and instead causes horrible turbulence features that impeded what's coming out of the turbine. Worse, in many of these housings the wastegate flap is set up to open so that the wastegate flow is aimed directly across the turbine outlet. The two flows do ugly things to each other once the wastegate is open.
Any divided dump pipe will attempt to prevent the wastegate flow from bashing into the turbine exit flow. There is some small chance that the divider might impede wastegate flow, but so long as the wastegate is large enough, this will only happen at low angles and the wastegate can always open a bit more. If the wastegate is a bit undersized, then it could be worse (for boost control). The divider will make the big cavity in the turbine outlet section a smaller cavity, which will edge it closer to the "ideal"....but only edge. Not actually a large improvement. But getting the wastegate flow out of the turbine flow is the main goal anyway.
The main problem is that nearly every dump pipe is a horrible compromise wrt to the ideal. There is usually a 90° bend downward directly out of the turbo, there is almost no conical expansion, etc etc. Even a pretty nice looking divided dump will still have that.
The main argument against divided dumps is that a big open dump offers more open area and a better pressure drop across the turbine, being better for spool. It might well be true. The argument goes on to say that the smaller diameter of the turbine dump on a divided dump causes higher velocity and therefore more frictional pressure losses (and therefore reduced efficiency) when on boost compared to an open dump. But that's probably not true. If the wastegate flow is interfering with the turbine exit flow, then the difference in the dump pipe friction is going to be small in comparison.
All in all, the best thing is to use an external gate so that you don't have to even think about this shit.
  • Like 2
Per forum rules, posts which do not relate to questions or clarifications on the item have been removed.
Advertised price is the choice of the seller.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
