Guys - besides the Nissan inline sixes - there are the less well naturally balanced V6's that can also respond pretty well to lots of mild changes cumulatively giving rise to better punch overall.
All my experience to date has been with the ubiquitous Magna 6G74 in standard 164Kw form.
The engine had done over 250kms and needed a refresh so it was whipped out and completely stripped down.
The following things were done extra to than just the usual rings and bearings, water pump and belt(s):
Decks surfaced and piston crowns surfaced to match..
Heads milled 60 thou.. de-shrouding of valves.. port matching.. contouring and cc'ing of combustion chambers.. 150% uprated valve springs.. new large aperture lifters..
Use of new old stock 6G74 'Ralliart' higher lift longer duration camshafts and vernier adjustable lighter weight cam wheels.. dialling-in valve timing at 6 degrees of advance over factory timing at advice of Mitsubishi development engineer Robt Green..
Use of 6mm phenolic heat blocks at the inlet to plenum, and at the inlet to throttle body..
Use of a fail to safety low temp thermostat ..and use of a thicker radiator core..
Replacement of the steel dynamic balancer with a drilled alloy under drive crank pulley..
Removal and sealing apertures of all EGR bits..
Removal of cat.. and installation of Advance headers and a 3" perforated tube and 2.5" perforated tube (50/50) open system.. no baffles anywhere..
HPC'ing of all of the exhaust components, internally and externally..
Heat wrapping of all the components from the collector to outlet ..Borla 3" outlet with ground effect 'droopie'..
Restricted hot water flow to throttle body.. K&N panel filter..
Use of 45Kv distributor.. NGK HT's ..and 'Pulstar' plasma field plugs..
Use of VP15 real time flashing chip to ECU ..all fields laptop set for 'power'.. 98 octane (Gull/Mobil/BP)
All the engine work was done by Rex Danby (NZ speedway engine development engineer)..
The vehicle really needed better handling/braking ..all rotors slotted for wet weather..
New old stock 'red' Koni Ralliart front struts ..Whiteline adjustable tower brace ..front camber kit..
Nolathane bushes front and rear.. and 20% uprated rear shocks..
To finish off I went through the car, removing EVERYTHING of extra weight, that was NOT NEEDED (the whole of the rear load floor, the spare, the tools, the towbar, the roof rack, rubber floor mats, and stereo speakers.
Edited by cagou
left out some stuff by mistake
https://www.sau.com.au/forums/topic/481940-na-v6s/
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
