Removing sump
Hey everyone
have a quick question does anyone have a photo of under there engine on a r33 coupe? I’ve tried googling but got not nothing
reason for this, is my engine builder finally has the new engine running in the car and is telling me the sump is now leaking oil around the welds. He needs to remove the sump to fix it, But he needs to take the engine back out of the car, for when he goes to reinstall, he wants to make sure it fits 100 percent. He says a cross member and other stuff is in the way. Surely this couldn’t be right?
couldn’t imagine you would have to take a motor out of a car just to put a sump back on?
Yeh generally its much faster and easier to take the engine out. Ive seen it done with the engine in by unbolting the engine mounts and lifting the engine enough to get enough room in, but its bush mechanics 101 and not something a professional mechanic should be putting his limbs at risk with.
Shouldn't be that bad though, engine out is a 2 hour job, 3 hours max.
3 hours ago, sic33r said:
Thanks very much everyone for the info
wow I’m surprised by the answers I got.  Well ya Learn something every day I guess
I get why you asked the question though, plenty of cars don't need to pull the motor out to remove the sump. We are just lucky I guess lol.
I've never done it but seem to agree with hardsteppa.
Removing lca's and cross member
VS
complete engine and associated bits
I reckon I'd go option A.
Option B sounds excessive but as i said I've never done and not talking from experience.
This feels a bit like do you prefer blondes or brunettes....
I'd take the engine out for sure rather than drop the x member (noting dropping the x member is a hoist only option in practice. Apart from anything else, it lets you have easy access to properly clean the bottom end for resealing the sump.
Trying to remove the sump bolts with the motor on, then trying to remove the sump itself is very challenging (even with a hoist).
If you were doing this on jack stands, it would add even more complexities. And no, you can't use car ramps as with the subframe out there's nothing support the castor rods/LCAs.
Motor out is better.
  • 3 years later...
I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it.
1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets.
2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine.
3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started.
4. The oil pick up can be removed with the gap available.
5. The oil pan can be removed now.
6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides.
7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off.
8. With one person supporting the oil pan the other can fit the oil pickup
9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal.
10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
Edited by elohim_imanu
 Share
    • Im thinking of getting some new wheels soon so i might keep a stock in the boot some how if i can fit and secure it. i will just buy a scissor jack from supercheap aswell. thanks guys. might even see if i can find a space saver just to get me out of shit.
    • Oh also, looks like it will be 3-4 weeks before they arrive - so no coolant change until then 😕
    • @soviet_merlin Managed to find my part and get it off Amayama. While I was at it and paying 9.75 AUD shipping for a $1 piece, I thought I may as well get some other plastic clips I broke 🙈  Thanks a lot for this link
    • The point of all that for me was to get to the PDM (yes, v37 is as fancy as a haltech) which is between the battery and the front inner guard.  In there, pins 80 and 81 on connector E125 are for hi beam according to the USDM manuals. I chose to intercept the high beam signal there as it is next to the battery and firewall so it is a good place to mount the fuse/relay for the LEDs. Unfortunately because you can't access the PDM with the battery in the car, it is difficult to test those wires are correct. The fuses for Left and Right high beam are marked on the PDM cover, so I checked continuity from the fuses to those pins with a multimeter, and it seems to be right. From here I need to splice a wire into one of those 2, and run it into the cabin for a switch, then run the trigger wire back to that general location for the relay. So, I removed the driver's side guard liner to check out where the wiring leaves the engine bay and enters the cabin.  Turns out, that does not happen behind in guard liner at all....waste of time, nothing is routed through there, so that was another 5 pin clips, 4 screws and a bolt of wasted effort All of the wiring is actually run across the separate compartment between the engine bay and the cabin under the cowling...so off with the windscreen wipers after all....
    • So....the good news is you don't have to remove the windscreen wipers to replace the 12v battery in a v37 (just). You do however have to remove: 1. Battery area cover (un clips) 2. Battery area trim (pin clips) 3. Nav side windscreen cowling (more pin clips, plus the trim between the cowling and the front guard, and half of the cowling to bonnet seal All of that gets you to here, with clear access to the battery While there, it is worth clearing out the leaves and dirt that run from the cowling into that well, my car had a lot of crap there and it is a guaranteed future rust hotspot
