Ayden Spiteri Posted February 13, 2021 Share Posted February 13, 2021 In need of replacing my steering rack, i know its probably a dumb question but i don't want to buy it and it be a waste of money Thanks in advance Link to comment https://www.sau.com.au/forums/topic/481958-will-an-r33-gtst-steering-rack-suit-a-gts/ Share on other sites More sharing options...
Rusty Nuts Posted February 13, 2021 Share Posted February 13, 2021 They are not the same, the GTST rack will be to suit a HICAS system Part No 4900119U00 The GTS rack is Part No. 4900115U05. They will physically interchange, but I would suggest the internal valving is different. Unknown result. Link to comment https://www.sau.com.au/forums/topic/481958-will-an-r33-gtst-steering-rack-suit-a-gts/#findComment-7947388 Share on other sites More sharing options...
GTSBoy Posted February 13, 2021 Share Posted February 13, 2021 It's probably a ratio difference. Can't see any reason why they would be incompatible in any other way. It's not even as if the rear steer was hydraulic on a 33. And even on an R32, where the rear is hydraulic, the two circuits are separate anyway. Link to comment https://www.sau.com.au/forums/topic/481958-will-an-r33-gtst-steering-rack-suit-a-gts/#findComment-7947398 Share on other sites More sharing options...
Ayden Spiteri Posted February 14, 2021 Author Share Posted February 14, 2021 Sorry i should also point out it was the front rack that needs replacing, alright no worries im just finding it hard to come by a gts rack at the momment but finding plenty of gtst's Link to comment https://www.sau.com.au/forums/topic/481958-will-an-r33-gtst-steering-rack-suit-a-gts/#findComment-7947426 Share on other sites More sharing options...
GTSBoy Posted February 14, 2021 Share Posted February 14, 2021 Yuh, it was clear that you were talking about front rack, seeing as you wouldn't/couldn't have HICAS on an NA car anyway. I was just pointing out that HICAS/non-HICAS shouldn't make a fundamental difference in the way the front rack connects to the car (mechanically and hydraulically) because it is an independent system anyway. 1 Link to comment https://www.sau.com.au/forums/topic/481958-will-an-r33-gtst-steering-rack-suit-a-gts/#findComment-7947427 Share on other sites More sharing options...
