15 hours ago, YouTRIPPIN? said:
i would but im dreading the fact that it will be annoying to take it off and on - and the chances of losing the fitment (like what happened when i took it off the first time)
also dont know how well the flush would be since it feels like the measurements of it is shorter - since theres gaps between the fender and the bumpers itself which was filled with silicone to cover it (shown in the pics above)
i like the look of this better tho its not as eye soring as my current one and looks more clean 🤣
Aye thats my best mates. I put that lip on with him.
We got the front from Ebay and the sides from body kit kingdom. Thats just the stock Base model 370GT Bumper. Can get them pretty cheap. SP ones are a bit more costly
LOL we're probably in the same page then VQ Australia, yea was speaking to him before and he helped me out 🤣
Edited by YouTRIPPIN?
yea me and him are admins of VQ aus haha
  • Haha 1
so im missing these brackets on both of my sides - where the fender meets the front bumper above the headlight. Wondering if this could be an issue if i replace my bumper with OEM?
You dont really need them.
Mine and my mates went away a long time ago. we just put a rivnut on there, actually easier to use than the OEM bracket
do you have a pic of it? just need to see how it can be done
  • 1 month later...
  • 2 years later...
you got any pics of these? might try and do this as well
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
