Up for sale is a set of Rays Engineering Forged Monoblock Prodrive GC-07J (designed by Bridgestone).
They have been discontinued by Rays/Bridgestone.
Being Forged Monoblock wheels, they're pretty light.
18x8.5 +25
18x9.5 +36
5x114.3
These were off a Z33 with Brembos and have Nitrogen Valve Caps on so assuming they're filled with Nitrogen.
Weren't the ideal offsets I was looking for but I don't see many of these pop up so grabbed them.
However I'm moving on to a different setup.
Has been stored in my closed garage.
They have some mild rash. One of them had a little spot of paint that had flaked off in the inner barrel. I had Fixarim patch this and fix the rash on the wheel.
However I didn't end up making time to correct the rest.
Front tyres have plenty of tread:
Greenlander L-Zeal56 235/40/18
Rears need replacing:
Bridgestone Potenza REO50A 265/40/18
I'd recommend Spline Wheel Nuts for these. Generally does clear Big Brakes but you'll have to do research on your own setup.
I haven't seen many GC-07 series wheels for sale in awhile. The only one I have seen recently is the GC-07C (first version):
https://www.vspecperformance.com.au/prodrive-size-used
More information including general size/offset setup can be found here:
https://www.prodrive-japan.com/en/products/gc_07j/size.html
https://www.prodrive-japan.com/en/products/gc_07j/matching.html
Pickup Wishart (would like for a pickup that way you can inspect in person if you have questions).
I've included some pics of other cars fitted with these wheels (unknown size/width/offsets).
$3000 ONO
Feel free to PM offers 😃
https://www.sau.com.au/forums/topic/481995-wheels/
Up for sale is a set of Riverside Trafficstar RTS Wheels
5x114.3
19x10 +26 (Kumho KU39 245/35/19 with ok tread)
19x9 +30 (Kumho KU39 235/35/19 with plenty of tread)
Has rash and some paint flake.
Cleared the rear Brembos of a V35 well. Just cleared the front Brembos.
I was going to get this polished and the rash corrected for future cars but decided to move on.
If you're looking for someone in Brisbane who does JDM wheel refurbishment, highly recommend Sak at
https://instagram.com/afterhours_ww?igshid=1162qk1wq0co1
$2K ONO
Pickup Wishart
https://www.sau.com.au/forums/topic/481995-wheels/#findComment-7947662
  • niZmO_Man changed the title to Wheels
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
