Hey All,
Hope everyone is well. Long story short, Bought a 2001 Mazda 121 Metro (Small Size Little Japanese Demon) with the most underpowered motor and feel, but still at a minimum a fun car, which makes a 60 zone feel like a space shuttle launch.
The few questions I have are,
one, got two oil leaks. One is coming from the sump plug (probably incorrect terminology), and another further behind. I was wondering since it is FWD if this could be trans or something else but got no clue, been underneath but a new oil leak started today but could be aircon or something i don't understand. I know one is defo engine oil, but the other, i didn't have time to check. If anyone is from Perth and has some time or interested (which i doubt anyone is) I'd owe them a life debt to look at the nugget.
Two, I am deciding if I am going to be a dickhead as per usual and cut the exhaust just before the muffler on the final 90 degree bend and stick it under the car and point it towards the underside of the side-skirt. The internal questions inside this are, one, if the pipe doesn't stick down or though the side skirt will it cause exhaust gases to pool underneath the car (close to fuel tank) and do i keep the muffler to f**k the cops off or do i just send it?
Three, my final stupid question. Now i know all of you hate pod filters and they are useless, but the pod filter i've added is definitely better than the stock 30mm pipe of airflow that the air-box was connected to. I have absolutely sketched the daylights out of this by finding out that adding a pod involves attaching pod to maf, and then i discovered an air temp sensor which i may or may not have drilled into my stock intake pipe and just plugged and walked away (yes i know it is bad and it is my first car sooo, sketchy is all i've got). To resolve this, I have got 3 inch tubing which will connect all fine (i've tested it) and made sure it plugs all together with the OEM parts, instead of the 2 inch tube. This new tubing is mainly stainless steel with silicon joining pieces and a somehow very well non-sketchy hole with a rubber seal for the air temp sensor ( i know, how advanced!). Anyway, back to the problem, the connection pipe i have made doesn't fit in the car.. , so does anyone have any ideas about how to go about keeping the pod, with new piping?
Anyway sorry for the headache that is this nugget, but, have to learn on a trash car to do something bigger...
Thanks all
Billy
Fix the leaks
Don't worry about exhaust, it will sound shit unless you get proper fat mufflers.
Intake modes will make no difference besides inhaling hot air and leading to less power, unless you have a sealed off box, but then after all that effort what will 1kW mean to you? Lose some weight instead.
