Disclaimer: This isn't a topic specifically related to forced induction, though the vehicle it applies to will be boosted, so...
I recently purchased a Series II R34 GTR radiator from Koyorad to install in my ENR34 project. I'm building a motorsport-level (or near enough, anyway) harness for it, so the addition of a threaded boss on the radiator to use for a coolant pressure sensor was enticing. Especially since I was buying a radiator, anyway. I have a large M16x1.5 bolt that I've easily threaded into the hole, but it still has a little play at full engagement. Does anyone know what the true thread size of this hole is so that I can buy an adapter for a pressure sensor?
If M16 is close, then possibly 3/8 BSP or BSPT. Or its simply a M16 tapered thread. Buy a set of thread gauges they are cheap and last a lifetime or two. My set belonged to my father.
Adapters you can get from
https://www.threadtoolsupply.com/thread-adapters.html
Edited by Rusty Nuts
additional information
I had the absurd idea of actually contacting the manufacturer through their "Contact Us" portion of their webpage and they insist that it's an M16x1.5 thread. I assume that once the o-ring on the bottom of the hex portion of the sensor its in that slight recess, combined with light torque would eliminate the play I'm feeling now.
Anyway, just updating this in case anyone searches this topic at some point in the future.
  • Like 1
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
