Hey guys! So long story short, I have an RB25 with a fair amount of work done, It's been running a GT3037S (From what I can tell).
It's housed in a .87ar, T28(?) I believe, well.. my problem is, the manifold I had, cracked, thrice. Welded it up, cracked again. So I'm on a mission to utilize my T3 Exhaust manifold.
I'm really hoping Discopotato chimes in ;) As I've seen him of great help on the countless threads I've read tonight, specifically with a T3 housing that had fitment issues on a supposed GT30 turbo some time ago.
Does anyone have the inducer/exducer size that would match the 56T version of the 3037? I know I'll have to buy a housing and machine it to fit the turbine.
https://www.sau.com.au/forums/topic/482079-gt303037s-information/
The GT37 compressor in 56 trim was around 76mm on the inducer and around 57 from memory on the inducer .
Turbine housings , you should be able to buy them in T3 flange to suit a Garrett BB turbo with a GT30 turbine . If running an integral waste gate should be easy to get .
Hi! I'll get pictures uploaded shortly.
It's definitely a .87ar, T2 flanged manifold, very short and stout the rear turbine housing is.
The only thing that sucks, is that the tag in the CHRA is missing, but everything I've found as far as Comp housing and such match to a 56GT 3037S (Gt30r).
I'll try to dig up the thread where someone had this same issue, I have an external wastegate so it is a bit harder to find, and hoping that someone can machine the housing to fit properly.
You cartridge is the same as that GT3076R 56T got . The part number is 700177-7 , sometimes shown as -5007 .
In the GTX gen 2 era the bearing pack changed to the G series type and the part number changed as well .
You could get a new old stock cartridge or a later one as they are supposed to be interchangeable in the turbine and compressor housings .
And I did look , T3 flanged non gated .GT30 single scroll housings should be available and are V band outlet .
Or you can use the T3 flanged integral gate ones with the Ford XR6 style outlet , been done to death on factory RB25 exhaust manifolds . Gated or not gated housings aren't cheap as they are made of Ni resist material .
Cheers , A .
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
