I sent a message to Daleo, but it seems he is now extinct.
The BNK010 kit (front and rear+links for 33/34RWD) - Does anyone have any .... any photos of this overlaid with a stock bar?
I know they fit a stock car. I used to own them, but for some reason I was ultra concerned with my LS swap.
However after using the stock bars, they f**king suck. And I seem to have a LOT of clearance when I have the car up on the hoist.
Way more than the ... 1? 2? mm of difference between the OEM bar and the 24mm bar. At least in terms of bar thickness. There's a lot of clearance now. I can't see why I was possibly concerned in the past.
Does anyone know if these fit pretty much exactly the same 'bends' as the OEM one, but are XYZmm thicker?
Can anyone define XYZ in regards to the 24mm bar on a R34 GTT front? (the rear has not changed at all, so is not of concern
https://www.sau.com.au/forums/topic/482083-whiteline-sway-bars/
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
