Gidday folks
Have just swapped a31 cefiro from rb20 to rb25 s1 using the rb20 loom and ecu. All I done with the swap is change over the injector plugs and used all the rb20 sensors (cas afm coils etc) . I left unplugged the aacv, coldstart, oil pressure sensor, and vct.
What I've tested
Test spark, has spark
Test light in injector plug has pulse
Rotate cas by hand with one injector plugged in can here it clicking
Swap coils
Swap spark plugs
Swap injector
Check for compression, has compression
Check intake manifold gaskets they are good.
No. 6 is not firing at all doesn't make a difference if coil or injector unpluged
From here I am lost for what to check. Its like it loses spark as soon as the coil is bolted to the head, the timing is off for just that cylinder or the loom was pinched during the swap... I'm unsure any help is appreciated
Edited by TOKKŌ TAI
Fix spelling errors
https://www.sau.com.au/forums/topic/482104-rb-not-firing-on-number-6/
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
