Got a bit of a situation.
Car has suddenly got a misfire.  Car from a cold start has no issue, runs normal etc.  Take it for a short drive after it's warmed up, acts normal and then feel like I lose a cylinder.  Only thing is as you put load on it getting past 3k RPMs, problem is GONE.  Then driving after a few minutes it's fine regardless of rpm.  It's kinda strange.
Original coils, new plugs, BRAND new coil pack harness
Pulled the rear 3 coils and pulled the plugs.. see attached.
Pistons look clean no carbon buildup.
https://www.sau.com.au/forums/topic/482113-r33-misfire-issue/
I agree it looks lean, but it doesn't really explain anything. I would try and log the behavior with Nissan Datascan, if you see stuff like MAF randomly dropping out at relatively constant throttle position then that could be the reason why. If MAF looks signal looks halfway decent but you see O2 voltage dropping to 0.2V or less for extended periods of time when the engine is not in DFCO then could be an ignition misfire, but if this is inconsistent I would be more suspect of the fuel system. Could be that the fuel pump isn't flowing enough until the FPCM kicks the fuel pump to full voltage. The O2 sensor starts reading well before the engine hits 80C coolant temp so you should be able to catch the behavior. NDS also has a function where you can disable individual cylinders, if you can reliably reproduce the problem you could get a friend to disable each cylinder in turn when the issue occurs to try and see if you can narrow it down to a specific cylinder, it should lose power/change engine note/rpm any time you disable one cylinder.
To try and make sure that your coilpacks are not the issue I would pull the coilpack bracket + coilpacks out, vacuum the valley thoroughly/remove any debris, then wash the coilpacks thoroughly with soap and water, they're fully potted so this won't cause issues. Dry the coilpacks thoroughly, then apply dielectric grease at the top of the boot near the spring and around where the spark plug ceramic insulator is, then put everything back together. Also make sure that the spark plugs you bought are not counterfeit or otherwise off in some way, I've had suspect spark plugs before and they made the car run ok for the most part but during idle I would feel the idle suddenly dip and the engine would have to open the idle air control valve up to catch the stumble before the engine stalled.
There's a guide out there on verifying the coilpacks more thoroughly but it's a real pain in the neck and involves pulling the CAS out, disabling all injectors, and removing all plugs + coil bracket and putting the spark plugs up in the air to while turning the CAS to see if the spark jumps through a stray path when nominally in a scenario where the spark plug electrode (ground) is not connected and therefore no spark should occur. Kind of dangerous to try though, make sure to discharge the plugs with some kind of insulated wire to the engine head to not shock yourself with like 10+ kV, the current is pretty trivial but it doesn't take much to cause problems with your heart rhythm.
  • Like 1
S1 / S2 RB25DET? How do you know its 1 of the rear plugs that is misfiring?
I've had similar problem - turned out to be a failing coil pack. Since you still have the OEM coils, suggest you upgrade to new ones.
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
