I’m doing the classic 400-450hp unopened 25det setup and I’m gonna sack my power fc since it doesn’t have ignition cut and you can’t do an anti lag tune on it or mafless setup.  So in your opinion what is the best ecu to get for a 25det? I constantly hear about link g4, haltech platinum pro and sometimes adaptatronic. In your opinion which is the best ecu to get? Cheers
https://www.sau.com.au/forums/topic/482115-best-aftermarket-ecu-for-rb25det/
When talking about the 'best' ECU's and Haltech in the same sentence, I wouldn't go with the platinum pro. The platinum range of ECU's were released in 2009 and are showing their age. I'm not saying they are bad, I use one myself, but they are not really modern by todays standards.
Have a look at the Elite range of ECU's and be guided by what functions you require as to what model is most suitable for you.
As for what the best brand of ECU is, it depends on what you want from it. This is the short version of what I think about them:
* Haltech - similar to an Apple product, quality products and you pay a small premium for it. The software is pretty to look at and easy to use. The hardware is more then capable of getting the job done. (I am a Haltech fanboy as I've had amazing customer support over the many years of using their products).
* Link - similar to a typical PC/Andriod product. Better value for money when compared to Apple however not as pretty to look at or as user friendly.
* Adaptronic - no longer considered a player in the game. Haltech took over Adaptronic back in July 2018 so they could get Andy Wyatt on their roster. While it's still 'technically' a separate company, it hasn't been the same since.
Probably the most important bit though, who is going to be tuning your ECU? If not you, ask your tuner what ECU they'd prefer to use for your goals and be guided by that.
  • Like 1
what sort of motorsport are you doing to need anti-lag, and what other features are you looking for to suit eg track logging, launch control, traction control etc?
Seems to me that PowerFC is the "best" ECU for almost all RB applications given its price and simplicity. You only need something more expensive if you have particular feature needs.
JEM in ingelburn, Sydney. Very reputable tuner of skylines.
41 minutes ago, joshuaho96 said:
Why do you need ignition cut rev limiting? Fuel cut is much safer for the engine.
Not gonna lie, I mainly want it for bangs, wanks and flames. But I also want it for launch control and to get rid of the lag during shifts and rev dumps and of course throttle response.I don’t plan on doing any motorsports. I also heard it’s very rough on the engine and that’s kinda what’s holding me back. I don’t want to blow thousands on a engine rebuild
29 minutes ago, Ben C34 said:
Flames mate, that's why
We think alike
Edited by IM-32-FK
MoTec M150
  • Like 1
38 minutes ago, admS15 said:
Power fc
ewww...
Minimum requirement is Nistune with Feature Pack. Has launch control, flex fuel, boost control OR WMI control (use the 3D boost table to control the WMI).
  • Haha 1
1 hour ago, blind_elk said:
Sorry, but if you aren't doing any sort of motorsport, why on earth do you need 450hp?
Power is like money, you can never have too much lol. I'm sure he'll want 550 not long after he gets his 450.
HP, similar to measuring your penis from your anus instead of from the base.
Still same size, just one has a perceived higher value.
We live in Australia, please stop using HP. We are not stupid Americans.
  • Haha 1
who is tuning & installing it?  Go with what ever the tuner recommends.
Personally Link G4+/x is my go to as have most experience with the software. They do a plugin for r33 and heaps of safety features if required will throw made flames on gear shifts & limiter
On 15/03/2021 at 1:21 PM, Murray_Calavera said:
What ECU does JEM recommend you use?
Ok I just spoke to JEM and he said go with the plat pro because they know it inside out. I found a used plat pro for $1570.
But I also found a nistune for $650 but some guy said the nistune will restrict my power to around 300kw.
Because I’m getting tired of being gapped by camrys and aurions
On 15/03/2021 at 4:26 PM, admS15 said:
Power fc
Keep it and spend the money burning a hole in your pocket on hookers and cocaine. Lifelong memories right there.
You're welcome 😉
power fc you can’t even do a e85 flex fuel tune that’s why
Just another thing. My current setup I’m going for is
3076r garret .82 t3 vband gen 2
bosch 1000c with plazmaman top feed rail and turbo smart fpr800
walbro 535
45 turbo smart external wastegate
Probably plat pro haltech
i currently have blitz return flow fmic, 3 inch turbo back with hi flow cat exhaust
stock intake and exhaust manifold
As far as the in/ex manifolds go, I’ve been told many times that the intake mani is still go for around 700hp and the exhaust manifold is good for 450hp too (Ben Moore a tuner from Victoria did a 351kw tune on a stock in and ex manifold on 20psi 3076r .82)
is it safe to run the standard head studs for 351kw on 20psi 3076r? I’ve been told they start stretching around 22-24psi
also I heard the blitz return flow restricts at 300kw. So what are some reasonably priced non return flow intercoolers I can get?
and finally does anybody know if a plazmaman top feed rail will clear the stock intake manifold and throttle body?
cheers
Edited by IM-32-FK
1 hour ago, IM-32-FK said:
$1570.
$1570 is a rort. I wouldn't pay that for that heap of shit.
Whoever "some guy" is is a knob lol. I'd go Nistune over Halal all day.
If you want the best its Motec or Emtron really.
  • Like 1
ECU's are boring. Coke and hookers are where it's at.
@Dose Pipe Sutututu can probably hook you up with plazmaman stuff and other parts you may need as well as advice. Pretty sure he had 370rwkw with stock in/ex manifolds.
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
