Hey All,
Just a few questions about painting the engine bay of my 2001 Mazda Metro 121. Basically I have chosen to paint it candy gold and am going to just cover the engine and take everything except the block, exhaust manifold and difficult stuff to move out of the engine bay while i spray and pray.
Just wondering if anyone would be able to help me on the things I can take out of the engine bay that are non-essential that don't need to go back in to remove the clutter of cables and tubing running everywhere. I notice aircon seems to take a hell of a lot of room up and, to be fair, it hardly works anyway so thats a go off, but would anyone give me any ideas of what else I can remove before painting thats non-essential to the car.
I will also say, the car is a piece of utter garbage, so I'm not too worried about removing stuff that won't ever go back in for resale, since I don't think it will ever resell.
Thanks Legends.
https://www.sau.com.au/forums/topic/482116-engine-bay-painting-questions/
Don't release the air-con gas to atmosphere, have an aircon guy evacuate the system, THINK about the planet. Unfortunately I cannot help with your other questions, I don't know what a Mazda Metro 121 is. Possibly get more responses from a Mazda forum.
  • Like 1
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
