  • 4 weeks later...
Nah.
with they GPS i tried to transfer the Australian maps onto it and updating it and not been able to get anywhere yet.
best i can do is Android Auto and then it all comes up Australian.
Everything else is in English so there is no problem there.
its just the GPS that won't give me anywhere else but Japan.
Wondering if i could buy a Nissan screen from a wrecker and swap it out but im sure its a long shot as it seems alotta stuff for the vehicle is held in these units.
On 4/5/2024 at 6:22 PM, niZmO_Man said:
So potentially worse than AUDM RedSport? :(
Looks better, has better safety features and android auto/carplay.
Sounds better to me
53 minutes ago, sonicii said:
you can pick up a 2018 AuDM RS for around $30k, can you really get a 2023 JDM V37 for that?  If so I may need to consider one... :)
There are 2 on car sales under $30k, $45k+ is the asking price for every other RS. I'd say they are either bargains, scams or listing errors. $50k approx gets you a 5 year newer jap import with a nav screen you can't read :)
Base models are readily available around 30k and would be much better value as a tuning start platform.
  • Like 1
at $45k, might be why they are still for sale.  Redbook range is $25-33k for a 2018 RS.
There is also a 2019 400R for $62k and a 2020 for $56k on carsales.  So I would expect a 2023+ to be more.
Personally, I don't think the JDM version looks much better, tails do. but front? meh.., so for that sort of $ difference, I would take a late AuDM Q50 and put a bit aside for new turbos when they go, but everyone has their preferences..
  • 2 months later...
Guys , just picked up 400R today , still getting used to setup ,I might be looking at maybe getting a exhaust upgrade in the next 6 months , any advise for a shop in Sydney?
  • Like 4
Hmmm, seems like these things are car of the week....we bought a q50 Red Sport today too (ironically, the one I said a few posts above is probably dodgy :rofl: )
Goes good for a stocker. Brakes and tyres need doing all round and it is way overdue for an oil change, but it seems good otherwise.
It was weird to be able to see (and even drive!) a car before I bought it, most stuff I get 2 or 3 grainy pics and an auction sheet I can't read, followed by a 4 month wait to see what I ended up with
  • Like 2
Nissan Oz are too busy trying to decide whether we need a Qashqai or Xtrail (whatever the difference is), really not a new issue. At least we can import cars they decided not to directly, at much better value.
BTW can I confirm ADM Q50 all have no spare tyre (just goop)? Is that the same in JDM skyline? I'm going to need to sort something, I can't do billions of highway klm without a spare
My Q50 doesn't even have 'goop', it comes standard with runflats, so no spare, no jack, no goop, nothing.  No idea what the JDM models come with.
I bought a 370Z donut (needs to be at least 18in to clear the akebonos), a spare jack and wheel brace and I throw that in the boot when I go out of town, saves having to spend the $$ and endure the downsides of runflat tyres.
Apparently if you are creative, you can make yourself a replacement boot base out of high density foam and fit the donut under the boot mat, but you lose about 100mm of boot depth.
  • Sad 1
I always drive with the tire pressure gauges showing the PSI because I'm paranoid about getting a flat tire and not knowing then keep driving and tear it apart. No amount of goo is going to fix a shredded tire.
My Q60 has the goo and the V36 had the goo too. Never used it but I have used the pump to pump up the tire to get home. Then I fixed it with a plug. Wasn't keen on the goo.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
