So let's say you have a 93 GTST, bone stock RB25 DET. You don't want a alibaba build but a budget build with quality parts. What would use to get to a dependable 350 wheel horse power vehicle? I am new to the skyline world, mine is on order at the moment and about 5 weeks out. So far, below is what I have picked up that I would need but I have no clue what parts/brands etc. Again, keep budget in mind if at all possible. No I don't want to LS it, thanks.
1. ECU (Haltech?)
2. Intercooler (what brand?)
3. Exhaust (trying to find a used one currently in good condition)
4. Intercooler (what brand, which model?)?
5. Injectors? (650? 700?) Max I would put the car to is probably 425hp or so. So, I don't need some crazy.
6. Fuel pump?
7. Manifold?
8.
9.
10. What am I missing? ^
Thanks for anyone that takes the time to share adult responses and assistful input.
Edited by sL0w_P0k3
adding info
Others will know better than me, but I'd guess a gtst will get to 260kw with a high flow standard turbo, powerfc, exhaust and possibly injectors. This is a well trodden path
  • Thanks 1
21 minutes ago, sL0w_P0k3 said:
Florida. But yes, I would like to know exactly what they are getting / prices and of course hp. :)
Australian prices or ridiculous American prices mate?
Put an ls1 in it.
God u Americans are lazy.
it takes more than 10 minutes to read through threads, see what has and hasn’t worked for various people.
you want people to spoon feed u all the answers.
keep reading, Google the brands people are using for various parts and then find out who can sell it to u the cheapest
  • Like 3
All of this. You will need intercooler and larger injectors. Add e85 for around 300rwkw
  • Thanks 1
You’ll need a precision 6870, 6 boost manifold, twin gates, 4in exhuast, cams, intake manifold, injectors, 3 fuel pumps, 100mm front mount intercooler, ecu, clutch, probably the a mechanical center put into the diff and you’ll definitely reach your 350hp goal with that
  • Like 2
  • Haha 2
9 hours ago, sL0w_P0k3 said:
Ah the ignorance of little kiddos. 😂
Thanks to those that are helping and not still sucking on mommies titties
Good luck with trying to find a good used exhaust in America. If only there was a way to make one.
I like how your thorough list has intercooler on it twice. Seems like you are really doing your homework.
Also please keep in mind looking to have a dependable 28 year old car that is going to also make more power than stock and that has had the speed wound back a couple of times is a fairly  unreasonable ask.
  • Thanks 1
Adult responses are always available, to those who bother to research, at least a little, first, Sarcasm is reserved for Oxygen Thieves. After all its a turbo charged straight six engine, NOT a Formula one conundrum.
Edited by Rusty Nuts
You got it precious!
Triggered you so much, you feel the need to keep on and on. Can’t get me out of your mouth: 😂
Edited by sL0w_P0k3
Haha.  You really are going struggle mate. Best of luck with the beast when you get it. Hope it's not too rusty and hasn't done 500,000ks {odometer will show between 70,000 and 140,000 regardless)
 Is the car you are getting an auto?
This guy is definitely going to have all sorts of pain owning a car like this.
You have to upgrade pretty much everything to get 260kw. The only difference between what you need for 260kw and 560kw is the engine build part. Still need every supporting mod, and buying a 260kw turbo is much the same price as a 560kw turbo.
  • Confused 1
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
