Hi guys,
I have this problem in my new setup like turbo overboosting but its not overboosting...its just cutting my turbo off for some reasons at high and low rpms at different boost at heavy load. Like its living its own life. One night i dont have issues and can go for 1 hour without problems accelerate all the time on different gears at heavy load about 1.6 bar and after 1 hour of drving the turbo cuts again. Like i dont have a fck clue what it can be....
How is this possible that car accelerates one time clean and other time turbo is failing, like the boost is unstable or something, ??
I put new GTX3071 gen2 two weeks ago because i thought my turbo failured but the new one has the same issues. It only goes clean every time at low boosts from 1 to 1.3bars. When i hit 1.5-1.7 it feels like overboosting at some point. So i have changed the turbo already.
On my manual turbo display i have overboosting set up limits  to 2.0 bars, i run external westgate precision turbo 45mm with 1.0 bar spring. My turbo housing is 0.83 A/R v band and 6boost exhaust manifold. Rb25det engine IS OEM did not any mods to it.
https://www.sau.com.au/forums/topic/482180-rb25det-high-boost-issues/
There's a difference between
  • A turbo genuinely not having proper boost control and overboosting,
  • A turbo making boost on one run and not making boost on another,
  • The ECU or a sensor cracking the shits and not working consistently.
Work out whichever it is, then start fixing that.
I am using actually LINKG4 but never tried to do any temp corrections by myself and i have hard time reaching my tuner right now. He quit his job. Actually i am in position where i can try to fix it myself or need to pay another tuner for complete mapping from scratch again.
I just went for a run on cold and it was smooth ride for 15 minutes on full loads at 1.7 bar so i guess all is ok with my car just overheating issues at some point.?? Maybe this is because of stronger turbo and i never do any temp corrections before. I had before gtx3071 gen 1 with max hp 550hp and did not have this issues. The problem start to occur more often on gtx3071r gen 2 max 650hp. I mean this gen 2 turbo feels much stronger even when i go only on 1 bar from spring, it has way more potential and its more aggressive.
What corrections should i do in the Link G4 ECU? I need some instructions which parameters to change. Is the log necessary for this operation or not? I need to drive around 1h to get this log saved if this helps with anything. Is this engine temp overheating limiter?
Based on how random this has been for you, it sounds like it could be fuel surge.
By any chance has this been happening when your at low fuel levels, and/or accelerating hard round corners or up hills?
Getting fuel surge will feel like your hitting a rev limiter or boost cut etc.
  • Like 1
PM me the tune file and a pc log (all channels logged) of it doing it.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
