On 29/04/2021 at 7:17 AM, BK said:
That won't cut it for a fuel pump. More like this on a heat sink.
100 Amp DC Solid State Relay with Heat Sink (windandsolar.com)
hey ben thanks again mate. attached a link of a 100amp one i found much like picture above. let me know if you approve im excited to give these a try. still learning way to much everyday
1 hour ago, BK said:
Yep that's it, the same as the Haltech or Crydom ones. That's a pretty good price too.
i wonder why they are priced so much differently look at these ones i found and no heat sink D1D100 Sensata/crydom, SSR, 100A, 100V (newark.com)
i dont understand how the heat sinks work. does it literally just pull heat from the relay as it warms up because of the shape of cooling fins much like some aftermarket diff covers?
Yep, purely heat dissipation. As Dose pipe said the heat sink is essential if PWM control is used. If just for on / off switching not so much.
  • Like 1
ok cool ill make sure too mount the haltech ones to some cooling fins and do it right. im done frying pumps. gotta slay some trees and finish up this mess, then we are gunna tune it up on e85
  • Like 1
23 hours ago, BK said:
So you are going to pulse width modulate pumps for speed control ?
this is how we wired it last night. one pump running all the time. other pump kicks in at 10psi. base fuel pressure is 45psi. nothing fancy yet. it pulled 580whp at 23 psi i was very happy with that. i havent got the built motor in there yet so this is as far as im going to push it for now. it feels extremely fast for now.
yes. i didnt even know what pwm was until you mentioned it bro. like i said i really am trying to learn all this stuff as i go im no where near on your level mate. the tuning, the pump setups, trigger kits, was all newish to me as im sure you know with the 100 questioned ive asked you over the year. i was just a very old school gtr owner that fixed my twin gtr as it broke back in the day.  this is my first shot at a hopefully reliableish single set up as well. i have been practicing my tig welding tho and getting pretty good,  im going to do all the piping on the bmw. just been busy with trees but taking a few days off hopefully soon to get some work done on the beamer, dyno vids uploaded, and hopefully some vids of smoking some hellcats and r35's.
  • Like 1
Well i know this thread got a little wanky, but i have to eat my foot on something and jump back to why i even started this thread. the whole problem was when we turned the set screw in to tighten down on the cherry sensor i must have ate my wheaties that morning because i crushed the sensor which is why it would read irratic. prp has since changed it to jam nuts one ach side of the bracket(prp wierdness) and once we tightened the jam nuts down we had to grind off the nuts on one side so it wouldnt rub on the stock crank pulley.  now made some serious power with the prp trigger and e85. doing another pull tonight on 25 psi
  • Like 3
6 minutes ago, Dose Pipe Sutututu said:
Sexual
oh mate. the building is literally falling apart every time we do a pull. wellness. very humbling unit i truely dont give a rats ass about jz's anymore. long live the forever oil starving/weakrod bolts/ head gasket/ bad oil pump RB26 who cares i love her let make some power see what a stocker can handle. going till we lift the head
  • Like 2
  • Haha 1
15 minutes ago, r32-25t said:
You may want to source another block to start the build with, they love to crack the decks with big power on stock internals
You sound experienced lol...
i have been building a motor the whole time the car build has been going on. just took some time with machinging as we were only using the stocker to fab everything up but now fak it gunna see waht it can do. it was a stock r33 motor in MINT condition. i bought 3500 dollars in sonic testing equipment and the block was unreal. i was considering sending it to herman an prp to confirm my test. but it was clear the block has seen no abuse the end bearings were still in great shape.  i couldnt care less if i broke the block ive read over a million threads about it im well aware good chap lol.  you can see it in about the middle of my build thread. the block is finally complete with a prp brace. Head is now ported and finished. just have to assemble it then we will install it end of month, so shouldnt have any cracking issues. im using a 6466 on the new engine. cheers
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
