on a minty nur 34 with a power fc his factory boost solenoid (the oem one fixed to strut tower) was open at the pointy end to atmosphere. No tube. No aftermarket boost controller.
mine, whether electrically connected or disconnected sucks a pulsing vacuum through that end at idle. It seems to make a slight difference to idle (open to atmosphere vs not)
is a factory boost sensor supposed to leak vacuum? is it normal to have it open to air?
Factory RB26 boost control solenoid is normally closed mate, so it's not leaking anything to atmosphere at idle. Standard setup opens when activated and vents in front of turbos - completely different to a Mac valve setup.
thats right.
however if you pull the front hose off at idle at least mine is sucking a vacuum like in rhythm. I can feel it. so is it broken? (it is new). It doesnt screw up idle like removing the other hose to it does though.
and why would this beautiful nur pfc have it open to atmo? maybe there was a hidden boost controller and this was not connected? would be news to the owner though.
Edited by syd_gtr
a) it isn't my car with the disconnected hose, I was curious if this was common.
b) I like to know how things work in detail. stock, the solenoid is normally closed, is it also slightly leaky?
perhaps it is better not to create any topics at all on sau - since everything has been asked before even if it can be difficult to find the exact reply, and of course there is a manual to refer to if one doesnt want to know the whys of something.
Skip to 6:00, it explains how the OEM boost control works. The "pointy end" I assume is the outlet that normally goes to atmosphere. In an RB26 it vents to the rear turbo closest to the firewall before the compressor, but after the MAF. The RB26 OEM boost control is a fixed duty cycle output on the solenoid, it doesn't seem to have any form of closed loop control or special intelligence. I've unplugged the wires to the solenoid on my car for now to run wastegate boost and there's not even a CEL if that tells you anything.
As for why someone would do such a thing frankly I have no idea. It's entirely possible it had an aftermarket boost controller at some point and someone ripped it out prior to sale with no real intention to reverse the modification in a clean way.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
