Hi, guys me again
since posting on these forums i have noticed something about the cefiros in which i havent noticed before. It is mainly on the front bar i was just wondering if they came with 2 seperate kits on them.
these are the 2 different kits that i have seen.
this is the front bar that im not sure if this is one that was released from the factory or not. this is also the one which i love :aroused:
this is the front in which i see on the majority of cefiro's
If that first front is not from the factory would somebody please be able to let me know what the name of the kit is. and also does the first kit come with just the front bar or is it the whole bodykit.
thanks again all
cheers Benny
P.S sorry to those who's pictures are up if they want them removed please PM me straight away.
https://www.sau.com.au/forums/topic/48223-bodykits/
it could be arranged... could bring in a few different ones with maybe some flared guards also.... funkymonkey see how much it would cost... u could probably get them for less than the price advertised too...
https://www.sau.com.au/forums/topic/48223-bodykits/#findComment-971239
The Autech front bars were a factory bar... just on the Autech version. If you were unaware of who autech are, they're a bit more than the HSV esque version of nissan, doing alot of factory specials ala the Stagea 260RS.
https://www.sau.com.au/forums/topic/48223-bodykits/#findComment-971264
yes i know who autech are... they also release the 4dr GTRs and many other special model nissans. which means its technically not nissan factory item... i dont count anything they do as factory... cause it isnt :)
https://www.sau.com.au/forums/topic/48223-bodykits/#findComment-971313
ew no... if it wasnt for the fat uras kit on the ceff i got i wouldnt look at it twice :P i hate them in stock form.
i agree completely, they have cred standard, but definately look a bit underwhelming.. like they drifted into the ugly gutter standard, but the autech one's look the good's, the uras kit is hot as, it's amazing what a nice front bar does for them!! :D
https://www.sau.com.au/forums/topic/48223-bodykits/#findComment-975046
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
