Hi Gents
Long time no speak lol. I was wondering if the RB26 AWD sump and the RB25 Neo Stagea AWD sumps were the same?
I totally understand that the diff ratios etc might be different. That doesn't matter though diff is being replaced.
Thanks
  • Like 1
  • 2 years later...
RB25 NEO AWD engines use a different bolt pattern on the sump than other AWD RB engines, the spacing and angle between two bolt holes near the input shaft area differ, measure them if looking at second hand sumps to ensure same as yours
The input shaft flange looks as if it might be a different length too ?, unsure about this.
Edited by RB335
  • Like 1
Interesting. The casting is different (but interchangeable) for R34 RB26 because it used a physically larger crown wheel than could fit in the early model housings, not sure if that is what you are seeing here.....
No idea why the block bolt pattern is different though, I've never heard of any sump that wasn't interchangeable on the rb AWD block
  • 1 year later...
I have information on this for anyone that comes looking again.
https://www.facebook.com/share/p/18gsbFaYTU/
The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
  • Like 1
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
