I think I have a problem with the ETS in my 89 R32 GTS4. The error appears to be temperature sensitive - the warning light only generally comes on after a while, comes on sooner on warm days.
Anyone know a shop in the western suburbs (around Werribee) that knows these little buggers and how to diagnose / fix them?
TIA
https://www.sau.com.au/forums/topic/482237-attessa-error-18/
Hey Greg,
I think it's the pressure sensor pump on the attessa pump.
From what I hear it's not serviceable so you have to replace with second hand or new pump assembly.
**** Update***
Looks like Frenchy has an option I would give them a call.
https://frenchysperformancegarage.com/products/fpg-nissan-gt-r-attessa-pressure-switch-replacement?fbclid=IwAR1n1PQu36Vzd0AzJXSgyFHyhpjBzYlR8kjtVuPrK_JIsCRaqHrf9mxYZnI
  • 2 years later...
Is that the ETS pressure switch? yes it goes above the read diff, and thumbs up for good parts but down for no/crap instructions!!! I have never tried to change the switch, you may need to drop the diff...
Well, finally got a response from Frenchy (amazingly almost immediately after I resent the original request with tracking). Looks like it is not really a DIY repair, so now need to find a mechanic, preferably Western Subs / Werribee, who can install this new pressure sensor.
TIA
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
