So I’m upgrading intercooler and fuel hanger/pump, have 1000id injectors e85-9 Garrett’s making 320awkw currently.Will upgrades to cam gears and type B poncams assist much in power gains on my Gtr32.
Im going to tidy the engine bay by powder coating the cam covers and figuring out weather to upgrade at this time. Advice would be great.
Edited by Matty George
https://www.sau.com.au/forums/topic/482238-cam-gears-and-poncams-next/
Hi again Matty. Just do the cam gears and keep the stock cams with your -9 turbos. If you cam it you will absolutely make more power, but your car will be slower everywhere except the drag strip.
Your call
  • Like 2
  • Thanks 1
Don't get Tomei cams if you're wanting new cams, get some decent Kelford cams, an intake cam gear (advance its mum) and install new valve springs (avoid Tomei junk), retainers and valve stem seals.
Yeah but with -9s car will still be slower for a streeter, even with the most baby drop in L182-A Kelford cams.
You're right though with the Tomei valve springs, how shit are they ? Caused me nothing but problems. The Tomei type B is, how did you put it, "made from a child's faeces"  😂 That still cracks me up.
That's correct, longer duration will move the torque/power to the RHS, however will also introduce more torque/power. This is where the intake cam gear comes into play, advancing that intake as much as possible (within reason) will pull that power curve back and the net result is nearly similar low RPM driveability but now with a wide power band :)
A bit of a balancing act.
Tomei cams & Tomei valve springs should not exist lol
  • Like 1
Yeah I've played with this on my -9 33 with this with Tomei cams. Ended up going back to stock cams with I think about inlet advance 4 and exhaust cam retarded 2 degrees.
I think -9s would actually respond to a 10mm+ high lift cam with less than 260 duration, but most people are not going to do such big head modifications with such small turbos, or twins at all.
You are completely right though, but cams just not worth it to increase 10 - 15w at most top end.
when you do end up picking a set of cam gears i would go with the kelford ones. i think there the only cam gears with the 5 mini helicoils and seem very high quality compared to tomei hks etc. cheers
  • Thanks 1
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
