So my question today for you guys is, and after looking everywhere I couldn't find anything. I'm really wanting to add a Chassis Mount Spoiler to my ER34 (GTT).
Does anyone know where I can get one, which is compatible with the skyline, and if it even is possible.
And if anyone has even done it. Thank you in advance.
https://www.sau.com.au/forums/topic/482240-r34-skyline-spoiler-questions/
1 hour ago, Roses Are Red said:
Just want to know if it's been done, If it's possible, and what it may look like.
How serious is the rest of your aero? is a normal body mounted wing not providing enough stability at high speeds at the track?
probably best to ask this in the Motorsport section
Why would it be legal?
Has it been crash tested?
Ever seen one ever on a production car?
Want to think as to how a chassis mounted wing somehow doesn't protrude
a) above the roofline
b) wider than the body lines
c) beyond the rear bumper
People who really require a chassis mount wing don't ask questions about buying one off a shelf. They would have made various other aero by themselves or a very expensive motorsport team.
It is very obvious that this one is intended to be bought for clout only.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
