Got to see the sedan for the first time today, as I am pretty pleased. Its actually in better condition than I expected. Has a few goodies which I will probably lose like HKS SSQ BOV, Tein height and damper coilovers and 5 Zigen cat back. Interior is perfect and is very straight. Just need a few cosmetics like new front lip extension, but its already booked in for a full respray, so its all good!!!!!! :headspin: :headspin: :headspin:
https://www.sau.com.au/forums/topic/48225-the-4dr-has-landed/
Cheers guys. Its been such a long wait, bought it back on the 28th of April, the joys of importing. Is always worth the wait though. :wassup:
Hey jlnewton nice mate nice always liked the look of the 33 4 door :)
so whats doing with the 2 door r u going 2 sell it?
hey should put all the goodys onto the 4 door :(
I am already there :) . Thats the only reason I have kept the 2dr up till now, didn't want to give away all those hard earned bits for nothing. The 4dr will get lots of free good bits from the 2dr. Some busy dodgy mechanic weekends coming up!
Very observant boys, The battery is up front, the washer bottle is in the RHS wheel arch. Sort of underneath the battery. Similar to 32s I think???? And the boot is nice and deep, goes all the way to the rear seat!!! Very cool, for a sedan. Much more usable space. Might be a series two sedan thing possibly. All looks very original. All original boot trimmings and washer bottles and stuff. If you look closely you can see the top of the reservior bottle near the air box. Or it might be the other way round, didn't look that closely.
Compliance should be sweet. He did the GTR for me in 4 weeks and he was a lot busier then than what he is at the moment. He reckons 3 weeks. Haven't had any problems with Tony, he is always keen to help me out.
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
