Just wondering if there is any synchromesh sequential gearbox for the r3x gtr ?
I believe only quaife is the only one to produce one ?
THe reason I would prefer this type of gearbox is for servicing...because dog type should be inspect quite often..
If I'm not wrong albin, samsonas, hollinger, ppe are dog type
Sequential synchro box is a total waste of time.
As above and Quaife do not make a synchro GTR sequential anyway - don't know where you got that from. Their current QBE91G GTR sequential is a choice of straight cut or helical gears, but it's still a dog engagement transmission.
Almost every semi truck in the US except for the very latest generations are all dogboxes. You don't hear about a semi trucks needing a transmission inspection ever 20k miles because it turns out that when downtime means you don't get paid people really make an effort to learn their transmission and treat it well. You also won't even get your full CDL if you can't drive a dogbox properly. If you hand your car to random valets, friends, etc, they're going to grind the transmission to death in a hurry. Synchro just makes sense on passenger cars for that reason, manuals are hard enough without learning out how to float gears/double clutch. People's brains turn off when you try to explain what exactly double clutching does.
3 hours ago, niZmO_Man said:
Dude thanks for sharing, this is very interesting ! What's the go though - is it $3k euro and you have to source and send them a transmission to convert ?
Thanks a lot for your answers, I appreciate!
Sorry I made a mistake for the quaife
Well what scare me is one brand (I don't recall which one) advice to dissasemble the gearbox every 5000kms to check....and based on some reading here I can see that such gearbox need quite short servicing...
I'm looking into the DCT which looks amazing !!
Only downside is the final gear is "only" 1.00 for the GS7D36SG
And also product is quite new so I hope we get some result/review soon !
OS giken with their OS88 state that, which is just covering their arse really. PPG early on with their H pattern had over 20000km without a teardown, proving that you can make them live without constant rebuilds. If you get to understand the mechanics of a dog box you'll understand what operational habits wear / damage them and what doesn't. At the end of the day they have to be unloaded to shift out of gear and synchronise the gear speed to select incoming gears without damage.
Sequentials are are great for this with dog boxes when strain gauge ignition cut is implemented for gear changes, as it unloads the gearset just long enough for the shift event to occur correctly. Shifting down gears is especially more tricky again with dog engagement, as it's easier to overspeed or underdpeed the gears on the shift event. Things like throttle blip ECU control, again usually in sequentials help with this gear speed matching to stop gear underspeed on the downshift.
This is why H pattern dog engagement boxes do actually require quite a fair bit of learning to get right, because the rev matching and gear unloading process is all completely manually done by the driver.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
