Just wondering if there is any synchromesh sequential gearbox for the r3x gtr ?
I believe only quaife is the only one to produce one ?
THe reason I would prefer this type of gearbox is for servicing...because dog type should be inspect quite often..
If I'm not wrong albin, samsonas, hollinger, ppe are dog type
Sequential synchro box is a total waste of time.
As above and Quaife do not make a synchro GTR sequential anyway - don't know where you got that from. Their current QBE91G GTR sequential is a choice of straight cut or helical gears, but it's still a dog engagement transmission.
Almost every semi truck in the US except for the very latest generations are all dogboxes. You don't hear about a semi trucks needing a transmission inspection ever 20k miles because it turns out that when downtime means you don't get paid people really make an effort to learn their transmission and treat it well. You also won't even get your full CDL if you can't drive a dogbox properly. If you hand your car to random valets, friends, etc, they're going to grind the transmission to death in a hurry. Synchro just makes sense on passenger cars for that reason, manuals are hard enough without learning out how to float gears/double clutch. People's brains turn off when you try to explain what exactly double clutching does.
3 hours ago, niZmO_Man said:
Dude thanks for sharing, this is very interesting ! What's the go though - is it $3k euro and you have to source and send them a transmission to convert ?
Thanks a lot for your answers, I appreciate!
Sorry I made a mistake for the quaife
Well what scare me is one brand (I don't recall which one) advice to dissasemble the gearbox every 5000kms to check....and based on some reading here I can see that such gearbox need quite short servicing...
I'm looking into the DCT which looks amazing !!
Only downside is the final gear is "only" 1.00 for the GS7D36SG
And also product is quite new so I hope we get some result/review soon !
OS giken with their OS88 state that, which is just covering their arse really. PPG early on with their H pattern had over 20000km without a teardown, proving that you can make them live without constant rebuilds. If you get to understand the mechanics of a dog box you'll understand what operational habits wear / damage them and what doesn't. At the end of the day they have to be unloaded to shift out of gear and synchronise the gear speed to select incoming gears without damage.
Sequentials are are great for this with dog boxes when strain gauge ignition cut is implemented for gear changes, as it unloads the gearset just long enough for the shift event to occur correctly. Shifting down gears is especially more tricky again with dog engagement, as it's easier to overspeed or underdpeed the gears on the shift event. Things like throttle blip ECU control, again usually in sequentials help with this gear speed matching to stop gear underspeed on the downshift.
This is why H pattern dog engagement boxes do actually require quite a fair bit of learning to get right, because the rev matching and gear unloading process is all completely manually done by the driver.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
