Hi Guys, so last week after a hard drive my R34 GTT has a pretty loud whining/wirring Noise coming from the front of the Engine.
Its hard to catch on Camera since theres a lot of windnoise coming from the Ventilator in the front, i guess you can hear it the best while idling after reving it:
https://www.youtube.com/watch?v=q3AWah4SUGU
This Noise gets louder with higher rpm, and is almost louder than the Exhaust at 6-7k rpm. It also happens with both clutch engaged and not.
My guess is either the Timingbelt (but what exactly? I dont think it tighten up itself harder than the week before) or a secondary belt like the alternator (since i had a popped headlight bulb after the drive last week, maybe it overcharged and killed itself?).
I know my way around a engine, but i'm not a mechanic and don't have proper equipment to lift the car and investigate blindly, so any hint is appreciated!
i would start by taking all the other belts off and fire it up(ac, alt, powersteering). if the whining goes away you know its from alt, power steering, or ac belts or pulleys.  if sound continues remove front covers replace timing belt, idle pulleys , and water pump. ive had my water pump make some wierd noises right before it went. now would be a good time to take that noise seriously and fix it before something bad happens. all the parts and trouble shooting i just listed shouldnt cost more than 500 quid. cheers mate. if you have never done a timing belt id have a mate assist you the first time to measure deflection proper. i come from a rb26 world but im sure its much like the neo in this case.
shouldnt have to lift the car in this case for anything either. if you are going to use a crank puller to remove crank pulley to do timing belt dont use a three arm puller use the proper one that screws into the small holes in front of pulley or you will crack or chip it on the outter edge and feel bad after. been there done that.
  • Like 1
my car was making that exact noise when i bought it and i thought i had major issues and i dont really know what the exact problem was but i replaced water pump, thermostat, timing belt and idler pully, hardware, new belts, problem was gone. keep posted im interested what you end up finding out. cheers mate
  • Like 2
Alrighty, a bit bummed since the Timing Belt and accessory (including water pump) was changed 6 months ago before i bought the car. But i guess i'll start of with removing all belts beside the Timing Belt and see if the sound continues.
i wouldnt be bummed mate its a small issue and a chance to work on your car. the fact that you know workwas done 6 months ago might even be more a reason something isnt right. my guess is pulleys on timing belt. good luck
  • Thanks 1
get your tools out find a few hours and get at it, wont be a better way to start the week, im finishing my e85 setup right now and its 5am no rest for the wicked. your issue wont take long to fix mate get er done.
20, 25,26, they are all the same, same procedure, same marks etc etc. But before you start replacing parts willy nilly diagnose the problem, no one has mentioned VCT they can make some horrible noises when they shit themselves.
yeah alot a like but different. as you state the vct is something i dont have and didnt know anything about so this vct noise is news to me. i dont know shit about a 25 but if it is the vct is should be easy to here with some ears and a pipe.
RB25DET Neo Cam Gears?
By Dyzzii, December 30, 2018 in RB Series - R31, R32, R33, R34 (1986-2002)
Read this it sounds like a similar problem
i think you know alot more than i do chap your posts are knowledgable, ive only learnt from experience and from guys like yourself. ive had this issue before due to the fact it happened after a hard drive im thinking it could be the vct, hope this chap figures his issue out.
Hmm that guy has no Video with sound in the Thread. However i read he has it on certain RPM ranges? Mine sounds throught all revs, starting in Idle and gets higher pitched / louder with every rpm.
I gotta see which shop here has a little bit of knowledge about these Engines, its rare since the Skyline was never sold in europe. Can't do it with my Tools at home, i can't even get the Fan of since theres a nut at the bottom of the fan which i can't reach from the top, space is very limited with the Mishimoto-Watercooler and i can't remove that cause that would need me to drain the fluid. Thats something i can't do on my parkingspot, else they'll rip my contract in two parts.
They already send me a "warning" letter that multiple people wrote them they're "scared" since i'm working on my car there and i'm not allowed to do any engine-work on the spot.
So a bit lost here. Thought that "whine" is quite distinctive and someone on this forum for sure heard it before.
I'm sure that noise is timing belt. Years and years ago, was out for a night of fun and was making same noise apparently I had stretched the belt. This was a mechanics diagnosis many moons ago...
On 15/04/2021 at 7:09 PM, MoMnDadGTR said:
did you ever get your issue figured mate.
Not yet, because i'm stuck in multiple places. I can't get the Fan out because two bolts are stuck and "rounded", these probably need to be drilled out.
I wanted to ease the Alternator-Belt but the Alternator won't move after loosing both Bolts on the "Tightening-bracket".
loosen both bolts then theres the tensioner bolt you need to back right off then your free, or just cut the belt and get a new one if your all bound up. there is a socket tool you can get rounded bolts out with. you should print off the manual for your car as well mate. here to help just ake your time and communicate more on the site and you wont end up with rounded bolts. should be able to take that fan on and off a million times without rounding the bolts....
Alright i made some Progress today!
I was able to loosen up the Fan and remove it from the Shroud.
After that i got so angry at the Alternator-Bolt that i removed it completely aaand i was able to move the Alternator!
In the FAQ theres written to just loosen the Bolt, but i had to remove it entirely to adjust the Belt. With that done i loosened it up quite a bit, even making it screech upon startup, just for a Test.
Since the Sound seems to be only apparent when the Engines warm i took it for a quick drive to warm it up (without Fan and loosened Alternator-Belt).
The Sound is still there, but without Fan i was able to make a better Video of it.
I guess thats not how a RB25DET should sound like, right?
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
