Hi, my agent has bid for a car successfully for me from USS Nagoya, and has sent me an invoice to pay. As USS auctions are not publishing the results, how do can I find out the actual bid price? Does the USS auction give some paper to the agent as a proof of the bid price? What kind paperwork I can ask the agent to privide to me as a proof of purchase?
https://www.sau.com.au/forums/topic/482265-actual-auction-price/
Whats that Auction number and car details. Ill see if the information is still avail.
Any good agent would send you a screenshot of the details as courtesy.
If in at auction i sometimes video record it for the customer.
If you don't trust your broker to tell you the correct price, why would you trust them to check out a car for you. Plenty of better ways to rip you off from another country if that is their intention
My suspecision is triggered by the fact that the agent passed me an invoice to pay, and not the auction record. On checking the USS auction record, the record for my car has been removed. Removing of an auction record is a paid service by USS. Why someone would pay to remove an auction reocrd, if it is not for the purpuse of hiding something? It is virtually impossible to tell whether an importing agent is trustworthy or not before doing a business with them.
  • Confused 1
  • 2 months later...
I can't even trust half the agents I've met over here in Japan. Who know's how you'd go about it from overseas.
The safest way would be to just buy it from someone with a good reputation - I've heard Rohab is good but can't vouch for it. Otherwise you can go over to Trust Kikaku but expect a price premium. Even once you get past finding a trustworthy agent, part of the problem is the cars aren't always trustworthy; you'll find 4s that should be R-rated and vice versa. You'll never know unless you can get a reliable third-party to check it over for you.
Good luck to anyone seeking to import via an agent.
  • Like 1
  • 4 months later...
  • 1 month later...
Who was your agent and are they from here or in Japan? did your agent video call you while they're bidding on the car? normally they wouldn't bid beyond your budget unless you have given them to okay to keep going. Even after the bidding end your agent would have the record of the final bid if not then it could be a money scam. Always go with someone with a good reputable company or import agent.
  • Like 1
Buy one from any other country that has imported them there are quite a lot of skylines for sale here in Australia depends what your looking for or try a land locked country where the chance of rust is much less
Edited by Dasmbo
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
