Hi guys
I'm in the process of buying the sensors for my rb25det track car and I'm looking at get the Bosch motorsport pressure and temperature sensor 0261230340 which I'll be mounting to my thormostatic Sandwich plate is the location of the oil temp sensor ok to use or is there a better place to mount it to get a true reading?
Any recommendations would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/482275-oil-temp-sensor-location/
Those sensors are a great idea to simplify plumbing and wire routing, hope they are reliable over time.
Any thermostat with a properly designed sender port should be fine to use; you obviously can't take either temp or pressure from the oil cooler loop in a system with a thermostat. There is some disagreement about whether you want pre or post oil cooler temperature, my view is I want pre cooler temp because I want to know the hottest the oil got.
  • 3 weeks later...
