i run a BC 2.9 e85 always 9/1 comp
presicion 7675 largest rear housing
best turbo for Hpattern/1000Hp
makes 1000Wheel at 40psi
like i said the large was a big thing for me, but original goal of 1000hp is more important
7275 may struggle making over 1100 (maybe 1000hub)
some bearable boost at 4300 and war at 5300
off course there are factors that improve spool or lean towards power like cams, pipping size etc
thing i found most benefits in traffic is shorter diff gears, if you have a 3.2 expect it too feel 3.4 with gears AND not too mention your target boost setting is reached sooner (time not rpm)
with more cubes like yours i’d definitely go the largest rear housing on whatever turbo you go, and remember there’s a 9k redline so plenty of power (unlike some other motors that don’t like more than 7-7.5k)
7675 sportsman is the perfect pic for 1000hp BUT “1100” maybe a 7685 if the power goal is more important than the low down power (like it is with me)
Went T4 Gen2 7685. Staying 3.2. Managed to speak to some CRD and Matouks customers who use a very similar combo to mine. 3.2/7685 some head spec variations. They say that you have to pull timing out of mid range to save bearings. Have heard (not seen) 1200hp+ hub results with my size exhaust housing.
Speaking of, no one seems to post dynobrests any more. That was one of my favourite past times. Reading all the combos and results.
Thank you everyone for your input. It always helps.
  • Like 3
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
