This is purely for personal curiosity.
We see these questions all the time. What sort of power can standard gear withstand. Rods, pistons, block, turbos, headgasket, fuel lines, injectors, gearbox etc etc etc. What about the head.
There are lots of flow charts for the RB26 head but what are the real world results. Because most people will not do a 5 axis cnc port and polish or go for oversized valves, shomless buckets.
When I was getting my headword done, the cost was over $10k. Most people will go for drop in camshafts, springs, maybe guides and retainers. Possibly a brush through the ports to remove some build-up thats collected over the years/decades.
So what's the most power that you know of that has been extracted through a "standard" head? No porting, no material removed of any kind. Just a change in lift and duration of valves.
https://www.sau.com.au/forums/topic/482314-standard-rb26-head-capabilities/
To be fair, this is a bit of a nonsense because if you're changing cams and therefore able to consider valve springs, then you can add enough spring to overcome any float issues that might be caused by high boost levels and you can run as much boost as the rest of the engine can handle. So, if you have tough enough rods, pistons and oiling, ability to run to very high revs (from the cams and springs) and sufficient fuel quality to handle the boost, you can just keep cramming more boost in and making more power.
If it were an NA engine then the question might be more meaningful. But the native flow capability of the head is not really the limiting factor until you have gone all the way out into rocket science territory with other parts of the engine.
There will be a limit. It would be easy enough to work out just by max air flow through ports but that's the absolute best case scenario which never happens in real world.
I have always thought that standard intake manifold is no good over 700hp. In one of the latest motive Cootamundra videos there is an R32 running a standard manifold with well over 1000hp.
It will be good to know what people have managed to do.
What was "true" for Jap tuners who couldn't deal with the ITBs in the 90s was never really true at all.
And what is that number? What boost are you chucking at the head? Air flow keeps going up with more boost. The limits turn up elsewhere (mechanical limits in the bottom end, detonation limits from the fuel, etc etc).
1 hour ago, hypergear said:
Fully stock motor. I'm getting 425awkws at 26psi at moment on E85 fuel with a GTX35 size turbo. Probably around 460ish kw in rear wheel.
Nice. So no cams?
What's it drive like?
Do you have any dyno graphs?
Well you would take the diameter of the inlet valve minus the area of the valve stem. There would be an absolute maximum volume that can pass through that area in CFM. Times that by 12 and then use that number to work out what is the maximum number in hp that that flow can provide on e85 or 98ron. I don't care about either number. If diameter didn't matter, why do people go for bigger turbos, injectors, exhaust. Everything has its limits. I just want to know what people have actually achieved. Like Andrew from Motive and Hypergear above.
Edited by khezz
Stock engine with head studs. Coming from Rb25det Neo motor, this is abit laggy for how I like it to be. Working on a different turbo direct at moment for same power and better response.
  • Like 2
Nice. That's some kick after 4000rpm. My lowmounts did thsame but with 200hp less at top. Are you going to keep it stock and see where you end up or do you have further build plans?
No. It is not that simple. What pressure difference between the plenum and the combustion chamber are you using to drive that flow? 100 kPa? 200 kPa? 300 kPa? 400 kPa? 500 kPa? There are people running that sort of boost on spark ignition engines. Each one of those larger numbers will mean more flow through the valve. It is not as simple as you seem to think it is. It's not even that simple in an NA engine where most people assume that you can only have almost exactly 100k kPa pressure drop across the valve, because there are many things you can do to get much better volumetric efficiency at certain points in the rev range. It is certainly even possible to get >100% VE on a stock head with the right cams and some intake tuning.
Boost is the great ruiner of your theory. Not enough flow? Just add more boost.
  • Like 1
I think Its already close to its maximum capacity at this point. I won't be able to run much boost into stock bottom end. So planning to upsize Camshafts that should increase the power to boost ratio.
  • Like 1
2 hours ago, hattori hanzo said:
620kw/146mph on standard head
Machined for 272 cams, but didnt touch the ports etc
Im blown away. Would love to see the dyno graph. Whats the rest of your setup?
I still have all my old HPI and Zoom magazines. I should repost the builders guide to rb26 from HPI magazine. There it says that 400kw is stage 5 and is only for the serious builder with a huge budget. How times have changed.
I guess that's why with porting, most workshops now say go all out or don't touch it at all.
Most recent update on the 30/5/20 post
it is currently having a new engine built, with a CNC (Rams Head)
http://antilag.com/forums/showthread.php?58554-DITB-GTR-Build/page17
the old zoom and hpi mags, although accurate in the day are so far out of date it isnt funny.
ECUs are now miles better
pump E85
turbo tech
Have you got your head yet?
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
