My professional  mechanic who is very enthusiastic about my 1996  RB 25 skyline ER 33 2500cc naturally aspirated engine
The car has done 280000 km.
The motor stops randomly  at times and infrequently. Maybe once a week,once every 3 weeks of short city driving ,
after 100 km of continuous driving or after just  10 km driving!!!
My mechanic cant determine the problem  He seems very knowledgable about this vehicle and has one of his own.
He  is a manager at an auto shop.
No rhyme, reason or pattern  why  this problem will occur .
Although the stalling never  happens when the engine is cold
The stalling tends to happen more often at the traffic lights when having braked but
it can happen on the highway.The car will not start immediately but if you wait a minute or so,
it will start.
All electrical power is present.
The mechanic gave the skyline  a bit of a tune  and adjusted the idle.
It had  a standard 100k service with platinum plugs about 40,000 km ago .
It has had an oil change and filter 1000km ago.
The symptoms seemed to mimic a Cam angle sensor problem although there was no back firing .
That was all he could think of .
So  I decided to have the sensor replaced (brand new ) even though he didn't  or push the idea.
That was an Expensive exercise ! $550 for the part
Recently I noticed black exhaust but the can angle  sensor replacement seems
to have made that problem disappear?
why would the black smoke disappear?
Anyway, how can I narrow down the problem to determine
the car stalling on the highway and at the lights?
All suggestions welcome.
Thanks in advance.
Edited by samuri
  On 03/05/2021 at 2:57 AM, robbo_rb180 said:
Have you checked ecu fault codes?
Could be iginotor getting hot, fuel pump failing.
Go through proper diagnosis before throwing parts at it.
Expand
 Thanks robbo,
Yes ECU checked but The age of the car means the ECU doesn't
provide a comprehensive a examination .Fuel pump replaced 5 years ago, however the problem is intermittent.
Wouldn't a fuel pump tend to be more regular with problems .
I thought may have had a fuel problem as well ,so have been using  Fuel doctor.
Ignition coils  replaced with spitfires about 40k ago
No doubt these are legitimate areas to focus on.
Other comments welcome
thanks
Expand
Not true. Good diagnostics available out of any Consult ECU. Tell me you got the "no fault" code.
Expand
No. Could be juuuuuuust enough to keep you going and then suck just a little bit too much every now and then.
Hook up a fuel pressure gauge to see what it's doing at low and high loads.
Look for bad wiring connections EVERYWHERE. At the ECU loom plug, at the ECU relays, at the field devices (CAS, AFM, etc etc), at the fuel pump, at the ignition barrel, at the fuse boxes, on the back of the alternator....everywhere. Write a list as you go. Be thorough.
  • Like 2
Expand
All R32/R33/R34 models have a comprehensive fault code mapping system, which is actually simple to check - do a search.    Fault code check is always the first thing to do.   If the original CAS had been faulty it would likely have tripped error code 11 (universal for all R32/R33/R34 models, I believe).      Replacing the CAS didn't fix the problem suggests there was no error code (CAS OK) and makes me wonder whether they've been checked properly.
Edited by SteveL
if you can get a thermal camera and check the fuse and relays, very handy for diagnosing faulty relays or high resistance issues.
Guessing heat issue in an electrical component.........
Expand
I will go back and verify with mechanic  about error codes
My NA R33 used to have most of the same issues you listed and was waaay slower than it should be but I had a couple of faults all together causing this. Weirdly it didnt show an engine management light or any codes though. Possibly some things for you to look at...
First of all I did a compression test for the peace of mind and so I'm not wasting money, which was all good.
The AFM was faulty (wires were corroded) so replaced with another one and fuel pump was also buggered, which was leaking inside the tank so I upgraded to a 255 walbro.
The TPS and IACV needed cleaning and adjusting.
Also the timing was out (originally thought it was the CAS also) and was all over the place when plugged in... The timing belt itself and tensioners were in a bad state so had a timing belt kit done. Runs spot on now, no problems at all and has all the lost power back.
Edited by ossy
Expand
Thanks for the info
  • 4 months later...
  On 15/09/2021 at 4:19 AM, Car Accessories said:
<link removed>&amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars, <link removed>and more. We can also organize Installation services.
Expand
Price on R33 bullbar and van racking please
<link removed> &amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars,<link removed>and more. We can also organize Installation services.
Expand
And a R33 tow bar that has the facilities for a bike rack as well for me please
<link removed>&amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars, <link removed> and more. We can also organize Installation services.
Expand
Also a luggage boot rack for a R33 Series 1 please.
The one that will fit over the rear spoiler because I don't want to change the aerodynamic down force by removing it.
Expand
I hope they have something, I've only seen bullbar kits for 34s in the past.
May be an image of food
  • Like 1
  • Haha 1
Oh you killjoy ! You took away the link !
We were just getting warmed up !
And I really like that aero package on that 34.
Looks like the aerodynamics of a . . . . . . Lambo . . no no Ferrari  . . .wait wait  . .  Maclaren  . . no no that's not it . . . . ah got it  -  parachute
  • Like 1
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
