My professional  mechanic who is very enthusiastic about my 1996  RB 25 skyline ER 33 2500cc naturally aspirated engine
The car has done 280000 km.
The motor stops randomly  at times and infrequently. Maybe once a week,once every 3 weeks of short city driving ,
after 100 km of continuous driving or after just  10 km driving!!!
My mechanic cant determine the problem  He seems very knowledgable about this vehicle and has one of his own.
He  is a manager at an auto shop.
No rhyme, reason or pattern  why  this problem will occur .
Although the stalling never  happens when the engine is cold
The stalling tends to happen more often at the traffic lights when having braked but
it can happen on the highway.The car will not start immediately but if you wait a minute or so,
it will start.
All electrical power is present.
The mechanic gave the skyline  a bit of a tune  and adjusted the idle.
It had  a standard 100k service with platinum plugs about 40,000 km ago .
It has had an oil change and filter 1000km ago.
The symptoms seemed to mimic a Cam angle sensor problem although there was no back firing .
That was all he could think of .
So  I decided to have the sensor replaced (brand new ) even though he didn't  or push the idea.
That was an Expensive exercise ! $550 for the part
Recently I noticed black exhaust but the can angle  sensor replacement seems
to have made that problem disappear?
why would the black smoke disappear?
Anyway, how can I narrow down the problem to determine
the car stalling on the highway and at the lights?
All suggestions welcome.
Thanks in advance.
Edited by samuri
1 hour ago, robbo_rb180 said:
Have you checked ecu fault codes?
Could be iginotor getting hot, fuel pump failing.
Go through proper diagnosis before throwing parts at it.
 Thanks robbo,
Yes ECU checked but The age of the car means the ECU doesn't
provide a comprehensive a examination .Fuel pump replaced 5 years ago, however the problem is intermittent.
Wouldn't a fuel pump tend to be more regular with problems .
I thought may have had a fuel problem as well ,so have been using  Fuel doctor.
Ignition coils  replaced with spitfires about 40k ago
No doubt these are legitimate areas to focus on.
Other comments welcome
thanks
Not true. Good diagnostics available out of any Consult ECU. Tell me you got the "no fault" code.
No. Could be juuuuuuust enough to keep you going and then suck just a little bit too much every now and then.
Hook up a fuel pressure gauge to see what it's doing at low and high loads.
Look for bad wiring connections EVERYWHERE. At the ECU loom plug, at the ECU relays, at the field devices (CAS, AFM, etc etc), at the fuel pump, at the ignition barrel, at the fuse boxes, on the back of the alternator....everywhere. Write a list as you go. Be thorough.
  • Like 2
All R32/R33/R34 models have a comprehensive fault code mapping system, which is actually simple to check - do a search.    Fault code check is always the first thing to do.   If the original CAS had been faulty it would likely have tripped error code 11 (universal for all R32/R33/R34 models, I believe).      Replacing the CAS didn't fix the problem suggests there was no error code (CAS OK) and makes me wonder whether they've been checked properly.
Edited by SteveL
if you can get a thermal camera and check the fuse and relays, very handy for diagnosing faulty relays or high resistance issues.
Guessing heat issue in an electrical component.........
I will go back and verify with mechanic  about error codes
My NA R33 used to have most of the same issues you listed and was waaay slower than it should be but I had a couple of faults all together causing this. Weirdly it didnt show an engine management light or any codes though. Possibly some things for you to look at...
First of all I did a compression test for the peace of mind and so I'm not wasting money, which was all good.
The AFM was faulty (wires were corroded) so replaced with another one and fuel pump was also buggered, which was leaking inside the tank so I upgraded to a 255 walbro.
The TPS and IACV needed cleaning and adjusting.
Also the timing was out (originally thought it was the CAS also) and was all over the place when plugged in... The timing belt itself and tensioners were in a bad state so had a timing belt kit done. Runs spot on now, no problems at all and has all the lost power back.
Edited by ossy
Thanks for the info
  • 4 months later...
On 15/09/2021 at 2:19 PM, Car Accessories said:
<link removed>&amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars, <link removed>and more. We can also organize Installation services.
Price on R33 bullbar and van racking please
<link removed> &amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars,<link removed>and more. We can also organize Installation services.
And a R33 tow bar that has the facilities for a bike rack as well for me please
<link removed>&amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars, <link removed> and more. We can also organize Installation services.
Also a luggage boot rack for a R33 Series 1 please.
The one that will fit over the rear spoiler because I don't want to change the aerodynamic down force by removing it.
I hope they have something, I've only seen bullbar kits for 34s in the past.
May be an image of food
  • Like 1
  • Haha 1
Oh you killjoy ! You took away the link !
We were just getting warmed up !
And I really like that aero package on that 34.
Looks like the aerodynamics of a . . . . . . Lambo . . no no Ferrari  . . .wait wait  . .  Maclaren  . . no no that's not it . . . . ah got it  -  parachute
  • Like 1
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
