My professional  mechanic who is very enthusiastic about my 1996  RB 25 skyline ER 33 2500cc naturally aspirated engine
The car has done 280000 km.
The motor stops randomly  at times and infrequently. Maybe once a week,once every 3 weeks of short city driving ,
after 100 km of continuous driving or after just  10 km driving!!!
My mechanic cant determine the problem  He seems very knowledgable about this vehicle and has one of his own.
He  is a manager at an auto shop.
No rhyme, reason or pattern  why  this problem will occur .
Although the stalling never  happens when the engine is cold
The stalling tends to happen more often at the traffic lights when having braked but
it can happen on the highway.The car will not start immediately but if you wait a minute or so,
it will start.
All electrical power is present.
The mechanic gave the skyline  a bit of a tune  and adjusted the idle.
It had  a standard 100k service with platinum plugs about 40,000 km ago .
It has had an oil change and filter 1000km ago.
The symptoms seemed to mimic a Cam angle sensor problem although there was no back firing .
That was all he could think of .
So  I decided to have the sensor replaced (brand new ) even though he didn't  or push the idea.
That was an Expensive exercise ! $550 for the part
Recently I noticed black exhaust but the can angle  sensor replacement seems
to have made that problem disappear?
why would the black smoke disappear?
Anyway, how can I narrow down the problem to determine
the car stalling on the highway and at the lights?
All suggestions welcome.
Thanks in advance.
Edited by samuri
1 hour ago, robbo_rb180 said:
Have you checked ecu fault codes?
Could be iginotor getting hot, fuel pump failing.
Go through proper diagnosis before throwing parts at it.
 Thanks robbo,
Yes ECU checked but The age of the car means the ECU doesn't
provide a comprehensive a examination .Fuel pump replaced 5 years ago, however the problem is intermittent.
Wouldn't a fuel pump tend to be more regular with problems .
I thought may have had a fuel problem as well ,so have been using  Fuel doctor.
Ignition coils  replaced with spitfires about 40k ago
No doubt these are legitimate areas to focus on.
Other comments welcome
thanks
Not true. Good diagnostics available out of any Consult ECU. Tell me you got the "no fault" code.
No. Could be juuuuuuust enough to keep you going and then suck just a little bit too much every now and then.
Hook up a fuel pressure gauge to see what it's doing at low and high loads.
Look for bad wiring connections EVERYWHERE. At the ECU loom plug, at the ECU relays, at the field devices (CAS, AFM, etc etc), at the fuel pump, at the ignition barrel, at the fuse boxes, on the back of the alternator....everywhere. Write a list as you go. Be thorough.
  • Like 2
All R32/R33/R34 models have a comprehensive fault code mapping system, which is actually simple to check - do a search.    Fault code check is always the first thing to do.   If the original CAS had been faulty it would likely have tripped error code 11 (universal for all R32/R33/R34 models, I believe).      Replacing the CAS didn't fix the problem suggests there was no error code (CAS OK) and makes me wonder whether they've been checked properly.
Edited by SteveL
if you can get a thermal camera and check the fuse and relays, very handy for diagnosing faulty relays or high resistance issues.
Guessing heat issue in an electrical component.........
I will go back and verify with mechanic  about error codes
My NA R33 used to have most of the same issues you listed and was waaay slower than it should be but I had a couple of faults all together causing this. Weirdly it didnt show an engine management light or any codes though. Possibly some things for you to look at...
First of all I did a compression test for the peace of mind and so I'm not wasting money, which was all good.
The AFM was faulty (wires were corroded) so replaced with another one and fuel pump was also buggered, which was leaking inside the tank so I upgraded to a 255 walbro.
The TPS and IACV needed cleaning and adjusting.
Also the timing was out (originally thought it was the CAS also) and was all over the place when plugged in... The timing belt itself and tensioners were in a bad state so had a timing belt kit done. Runs spot on now, no problems at all and has all the lost power back.
Edited by ossy
Thanks for the info
  • 4 months later...
On 15/09/2021 at 2:19 PM, Car Accessories said:
<link removed>&amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars, <link removed>and more. We can also organize Installation services.
Price on R33 bullbar and van racking please
<link removed> &amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars,<link removed>and more. We can also organize Installation services.
And a R33 tow bar that has the facilities for a bike rack as well for me please
<link removed>&amp; Vehicle Accessories at super low prices for the world's biggest brands online &amp; in-store. Get your quality Car parts online, Van Racking, Roof Racks, Tow Bars, Bull Bars, <link removed> and more. We can also organize Installation services.
Also a luggage boot rack for a R33 Series 1 please.
The one that will fit over the rear spoiler because I don't want to change the aerodynamic down force by removing it.
I hope they have something, I've only seen bullbar kits for 34s in the past.
May be an image of food
  • Like 1
  • Haha 1
Oh you killjoy ! You took away the link !
We were just getting warmed up !
And I really like that aero package on that 34.
Looks like the aerodynamics of a . . . . . . Lambo . . no no Ferrari  . . .wait wait  . .  Maclaren  . . no no that's not it . . . . ah got it  -  parachute
  • Like 1
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
