Spent the weekend finally tracking down my sun roof leaking issues. Snaking the drains has not been effective. SO... I removed my entire headliner and found horror! Both front corners of the front sun roof frame are completely rusted through and crumbling apart. Essentially, the water has no way to make it to the drain as the corners themselves are gone.
Looking for someone that may be parting out a car and willing to sell JUST the front sun roof frame. I don't need the glass, motor, or shade. I will post up pics later... unable to at the moment.
Will also require shipping of the frame.
Thanks,
BC
https://www.sau.com.au/forums/topic/482351-wtb-front-sun-roof-frame-s1-1997/
Yeh that's bad and seriously perforated.    That said, depending on the complexity of the channel design on the 'other side' (hidden in the photos) it should be possible to cut out the rust and TIG weld in replacement sections.     Quite a bit of work but doable with the right equipment and skills.     After that it's appropriate corrosion protection treatments - zinc plating if possible but appropriate corrosion resistant primers, paints at the very least.
Looks like the original part came with a basic paint job so corrosion was pretty much inevitable.
You're in Germany from your profile, so spares are probably thin on the ground (??) if that turns out to be the only way to go.     Maybe the UK is a possibility where Japan imports are probably more common.
According to Amayama some of these parts are still available new....but not cheap.
Another option is specialists that might be able to source these parts from Japan like Import Monster, secondhand or new.
    • 6 foot 91kg.   Thanks Brett, ill have a look into them!   Whoa 197 haha, I'm about 182 but not that far behind you in weight. My back is probably a little wider than most people my size and weight so I would most certainly need the XL seat by the sounds of it.  The car is insured to drive 1000km a year (might up that at some stage) but it would likely take me at least 5 years before I would ever get close to 15,000km. If I don't buy the real ones I kind of feel like I'm cheaping out though lol Spent all this money on good quality parts every where else just to cheap out on the seats? probably my OCD.  I did find these guys who are more local to me and have copy seats in stock.  https://vosta.com.au/collections/reclining-bucket-seats/products/japan-stadia-ii-gradation Or if I want to go genuine   https://www.carmodsaustralia.com.au/brand/bride-racing/?srsltid=AfmBOooYKfh5btzB8-ezRTTokM0AqQ3GyWKcfutaMRWBzosRLNSFQhLt
    • Good. I was worried we were still talking about the block. Yes, larger baffled sump is a good idea. Do not touch the pump unless you're going on a whole build saga. Read the oil control thread on here - at least the last 100 pages or so. We drew some reasonable things together in there. The short version is that venting the sump is more important than almost anything else you do.
    • Perhaps just get a proper mechanic who is good with Nissan autos (they were more or less the same across all the RWD, FWD, 4WD cars at that time, even if they were actually different boxes) to give it a good going over. He might be able to plug in a Consult or other scan tool and find out if it's got some fault codes. Otherwise, my approach to the problem if not liking the way the auto was workign behind my RB20 turbo, was to drop it on the workshop floor and put in the manual box that it really needed. That solved all the auto problems.
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
