hey,
anyone used 3D Racing Solutions (https://3dracingsolutions.com/)? I put an order in on the 30th December and at first they were quite responsive and advised there were delays, when i chased up after the ETA I was told next week (approx 15th Feb).
I received an email saying they had an issue with the design and are fixing this. I am happy to wait as i need the part.
I have since made several attempts via facebook and email and have received no response.
If anyone has any alternative way to contact them it'd be much appreciated.
https://www.sau.com.au/forums/topic/482379-3d-racing-solutions/
It was the Centre MFD Dash Mount for the Haltech IC-7 https://3dracingsolutions.com/collections/nissan-skyline-r32/products/r34dashmfd
I also offered to take my car down if it helped them with any fitting, design issues they were having.
i suspect it will be an absolute pain in the arse to print that part without a shit ton of supports.
it will also show up a shit tonne of layer lines which will require a fair bit of post processing, fillering and painting (which i believe he does to most dashes anyway), he's probably flying through the easier jobs first.
Still, it wouldnt hurt to reply to your customer base!
yea agree its a heap of work, if its a main listed product of yours i would expect you have priced appropriately to make it worthwhile and actionable within a timely manner.
I dont mind waiting i just want to know im not forgotten / its getting done (and if not refunded).
Thing is, if he's already developed it then all of that work is already done, he doesn't have to redo the print design every time he prints one. Literally just press print on it. And then there's a couple hours work in bogging and painting it, so it isn't a heap of work at all.
Obviously if he has 3 months of orders stacked up and one printer than that's going to be where the hold up is, but he's gotta talk to you in that case.
On 09/05/2021 at 7:51 PM, Exodus01 said:
hey,
Hey @Exodus01!
The guys over at 3D Racing Solutions have been under the pump lately... They're actually back-logged on orders, and have stopped taking additional orders at the moment!
I know the owner, and have messaged him to try help you out. Will keep you posted on a response.
just an update, guessing my order was not at the painter and ready to be shipped as my order was just cancelled... I did receive a full refund (thankfully). extremely disappointed, coming up to a 6 month wait + the tease of it almost being ready and now nothing and also now have no way to fit the ic7.
Edited by Exodus01
  • Sad 2
Nice build mate, hectic work!!
 I'm going to see if I can model one myself..  im terrible at 3d printing ahha.. was thinkin I'd buy a new mfd outer shell and see if I can print an inner bracket to fit it https://vegaautosports.com/collections/r34-gtr-skyline/products/mfd-hatch-dash-finisher-to-suit-nissan-skyline-r34-gtr
If there is a 2D dimensions sketch available for the IC7, then I would be happy to adapt the drawing I've done for an AIM MXS into the factory MFD surround.
Just beware with the factory MFD surround though, for one it is very small - not sure on the IC7 dimensions, but the AIM dash literally only just fits and is in fact cut off by a few mm. And second, it isn't actually flat, the bottom of it sits forward because the OEM MFD has a second piece of trim that covers the gap. So you will have a 15-20mm gap in between the bottom of the display and the MFD surround.
  • Like 1
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
