Car is hard to start when cold. just have to give it some gas. changed cold start valve did not help issue.
Car coughs at idle about every 1-3 seconds. cleaned and inspected IACV all clean and works. still not helping.
Car stalls with clutch pushed in when coming to a stop when cold. only happens 50% of the time.
Checked TPS all good and reset.
Car is stock. Brand new OEM coil packs, new spark plugs, new OEM fuel pump and fuel filter. Confirmed no vacuum leaks.
MAF is clean. Idle does not hunt. wiggling the plug to MAF when car is on doesnt affect idle.
Throttle body is clean and cable tightened correctly.
I checked the forums here and what i said above is what people say will fix the issue. The coughing idle is what really bugs me. everything else i can live with.
Car is perfectly fine in every other regard no issues anywhere else.
No i cant just borrow parts from another skyline.
Is the AAC valve blanked off or blocked off? they seem to fail quite a bit and most people just block them off to stop the high idle.
Consequence to this is pretty much what you're describing.
Another way around all this, convert to DBW and throw the IACV, AAC valves all into the bin ;)
No its not blocked off in any way
This stupid thing, it sits under your top part of your plenum. A karnt to remove/reach
Iacv Rb20
I just finished installing a brand new one of those today. It didnt help the problem. is blowing into it just making sure it starts to close and works?
If the motor is cold, you should be able to blow into it, once it warms up it closes up.
When you unplug the O2 sensor does it idle better?
I forgot to mention that the O2 sensor is also brand new but i will try disconnecting it in the morning. Thanks for the help so far mate.
10 minutes ago, admS15 said:
You forgot samsonas, slipping brah..
fuark.. soz...
Let's try that again
All else fails, CAN O2 wideband, IAT, DBW, DBW pedal, Samsonas,  modern ECU conversion 🤣
  • Like 1
  • Haha 1
Iacv Rb20
Hey @Dose Pipe Sutututu just to be clear that is an IAC valve, or air regulator valve as the manual calls it, not an AAC valve. The air regulator valve gets a constant 12v on it fed from fuel pump relay and the AAC is pulsed on the ground by the ECU to control the solenoid duty.
To test the air regulator valve as per the manual, without power the valve is only fully open at -20 deg. C, half open at 20 and fully closed at 60. If you 12v power them they are supposed to gradually close fully within 7 minutes. Resistance across terminals is 75ohm at 20c ambient.
@BK perhaps I got the terminology wrong, that device isn't the idle control valve though
The idle control valve sits on the plenum itself. The IAC valve pretty much just has a diaphragm that closes as the motor warms up.
Yes it does exactly as I mentioned above. It is actually powered to heat up and close, not just engine temp. IACV is probably not a very correct name for it either, but it is certainly not the AAC valve which has the idle screw and solenoid on it as you would know.
Should really be called the fast idle thermo valve, cold start air valve, or something similar that at least indicates that it's associated with cold start air regulation. My advice as I've been working through my own car is to get Nissan Datascan with a Consult cable and take logs when the car is misbehaving. You have to see what the ECU is seeing to understand why the engine is behaving the way it is. The ECU itself has very weak self-diagnostic capabilities, basically the only codes it throws are for things like open circuit/short circuit. All the sensor plausibility stuff is entirely on you to diagnose. How stable are AFRs when the engine stutters at idle? What does the MAF signal look like? Really meditate on the logs before you throw parts at the car. If you're suddenly losing consult cable connection during those drop-outs I would start suspecting the ECU or whatever is supplying power to the ECU.
I just purchased data scan with cable a few hours ago. Thanks for the help.
Once you get logs of the issue feel free to upload it here, I can try and stare at it and see if anything stands out as well.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
