7 hours ago, Nocsyn said:
Really dumb question but have you checked your timing? One random but crazy suggestion is could possibly the cat be clogged?  You replaced everything else....
good luck man.
I had a shop that specializes in imports and high end cars check the timing about 3 weeks ago. everything was all good. plus i had the timing belt and water pump replaced 3 years ago. Thanks for the help.
18 hours ago, Dose Pipe Sutututu said:
If the motor is cold, you should be able to blow into it, once it warms up it closes up.
When you unplug the O2 sensor does it idle better?
i unplugged the O2 sensor and absolutely nothing happened
