ight so my cars been f**kin me around bad lately, like it starts misfiring once its warm and even more so on low revs, however its way better on high revs (if i drive like an arse hole)
Anyhow
in an attempt to fix this shit ive cleaned up my injectors and fuel rail (so theres 0 fuel in the pipes past the filter), so I plugged everything up and when i turn the key i dont hear the fuel pump prime, i crank it a fair few times pumping the pedal and I get nothing.
im thinking about unplugging the return fuel line from the fuel rail to kinda bleed the the system of air, would that work???
.....or does this sound like a fuel pump issue as its not even priming
PS ive already changed dizzy, AFM, ecu, checked TPS, new sparks, 95% sure the last owner changed leads, just in case your wondering if its that.
also sorry for my poor English
There should be no connection between what you have done and the problem that you have. So, either you have a bad coincidence, or you have somehow f**ked something else (unexpected) while playing with the fuel rail. Sadly, we'd only be guessing as to what that accident might have been.
If the pump is not running, then the thing you should be doing is fault finding the pump, starting with the power and earth, to see why.
sorry to waste your time man..... i just forgot the 3 earths at the back
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
    • That depends, someone might offer me a good price to resell it Mark... Ha ha ha!   I can get it wrapped in a really nice looking carbon fiber vynil if you want?
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
