 My mind is at a loss here, would like some light shed on this please and thank you
Bought my self an rb25det neo wgnc34 to install on my a31.
The engine came with an ecu and everything that is needed to get the car running. The engine is bone stock, i only have modified the exhaust, i have a 3 inch pipe all the way to the back with a magna flow muffler at the end.
When the engine was installed the car ran great for 1 week then i started to notice some problems. Bad idle, loss of power, and sometimes the car will surge and would not let me pass 2.5-3 rpm.
I changed the maf sensor and added new plugs, that got ride of the surging and the car is now running well, only problem is that its running super rich.
The interesting part starts now. I though my car would need a tune and it should run fine. So i started to look at the ecu and the engine and doing research so i can get my self a compatible aftermarket ECU.
While doing research i realized the ecu that is currently have on the car belongs to an NA stagea, is that possible?
During the first week the car was getting into boost and i was feeling the turbo and hearing it spool and i can feel the car get into boost, is that possible with an NA ecu?
Could my car be running rich because it has an ECU that is incorrect?
The ecu number is 23713-0v711
https://www.sau.com.au/forums/topic/482406-rb25de-ecu-vs-neo/
  • PranK locked this topic
Guest
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
